abs light on
R
rollavvti06
minnesota
The problem.is at the pigtail at the pump i cleaned it and the.light went off but would come on after trying the abs a few times so does anyone have a spare pigtail i can buy cause where i think it is bad is too close to the end to add a new wire
R
rollavvti06
minnesota
Well today i topk the abs pump and the cumputer mounted on top of it apart today and cleaned it all and checked for corrosion. I put it all back together and the light has now come.back on. I was reading on the f150 forums about the two wires connecting the two gets corroded and fails to power it. So if anyone else has the same problem as me just read my next post on how to go about finding and cleaningthe area, every where i lopked online was pretty un clear on what they were doing
R
rollavvti06
minnesota
Remove the air box just pull it out and use a use a screwdriver to take out the mass airflow sensorthen you will see we're all the break going to meet together at one box that has a plastic top with for two connectors that you can see then there are four t25 screws that need to be removed then you will see a clip umderneither with one red and one black wire underneath to on the plastic module body that is where the problem is that everyone has been having with the corrosion and you just pull up on the plastic module ofthe ABS pump it will then be 6 silver pins on the pump make sure thps are clean and the red and black wire look and feel good. Put it all back together and see if the ligjt goes out if so try the abs a few times. Well thats what i did and it fixed my problem
