AC help please
Boriqua491
Orlando
Hello, I'm new to this forum and I need some help with my AC.
We have a 2005 Eddie Bauer 4x4 with auto climate control up front and separate system in back.
The problem started with the front fan not coming on for a few minutes then coming on and working fine. This happened a few times, no front fan then later it would come on. Now the fan doesn't come on at all. I found the blower resistor behind the glove compartment and checked the connection and that seems fine. Is there a way to bypass the resistor to see if its a bad blower? Is there a way to check the resistor? I'm trying to avoid buying the wrong thing.
Thank you!!
Bedrck47
Elizebethtown, PA
The blower motor is inoperative — DATC
Circuitry short/open.
Blower motor relay.
A/C blower motor.
A/C blower motor speed control.
Go To Pinpoint Test Q .
The blower motor does not operate correctly — DATC
A/C blower motor.
DATC module.
Go To Pinpoint Test R .
