Air in brakes
Jamesbaggins
Temple tx
I'm working on a friend's dad expo, changing front rotors and pads. When I got the truck the brakes were kindy spongy (going to the floor) but I thought it was because his pads were completely done. Calipers were rusted to the pads and rotor pretty good had to disconnect the brake lines to get them off.compressed calipers without the lines on (probably a big mistake). Replaced everything and proceeded to bleed the brakes. Rear bled no problem front brakes I have spent almost two days trying to get all the air out. Used pump and hold method, then got a vacuum bleeder. The strange thing is that no matter how much I pump I'm not getting any fluid I've had fluid come out so I know there are no clogs. The vacuum bleeder will not hold a vacuum on the lines either. The pedal gets slightly stiff when the truck isn't running. But when the truck is on it goes straight to the floor. I been racking my brain for two days trying to figure this out.
Temple, Georgia
Welcome to the site.
Crack the line on the caliper while someone is holding the brake pedal. If fluid comes out then there is a problem with the bleed screw. If not then there is a problem farther up the line or master cylinder has failed.
J
Jamesbaggins
Temple tx
I don't think it's that I've had fluid come out of the bleeder, just never a continuous flow from the front.
