I failed to take pics along the wait with only a few to show for my efforts lol. honestly it's a pretty easy install, here's some things of note:
started with the top 3 bolts which are 15mm, just use a ratcheting wrench. then undo the strut bolt which is 30mm but make sure to use a deep well, mine was shallow ( go figures the only shallow socket that I don't have a deep one for ) so I had to use channel locks and crack open the back end; the back end ( captured nut ) is a 27mm and can use shallow if wanted.
then move over to the next bolt in middle which are same sizes. I did hit them with PB Blaster for a few hours while waiting for the parts to be delivered, however with my Mid Torque wrench I don't know if I even needed it lol.
the air line and plug is easy to deal with, and my strut assembly came very easily out of the upper mount plate and lower arm.
all in all, easy job just make sure to have a serious torque wrench impact drill on hand, or rent one if you need to.
