Erich Zeppelin
I just got my 1999 Expedition E.B. driving home I noticed the Check Suspension dash light was on so I crawled under her, the rear looked great, moved to the front and found that both sway bar links were broken, bought and installed new ones,then I noticed that I was sitting on the rubber stops so I started looking at why my compressor was inop. found that the PO had turned it off at the switch. I turned it back on, fired her up and she aired up. My problem is the rear airs way up but looks like the front isnt as high as she should be, only about two inches from the stops that she would rest on, and she wont air down when I shut her off and open the door..........
