ALLA LED headlights issue
ViperVette
Elida Ohio
I installed ALLA LEDs in my main headlights and my fogs on my 2021 XLT-FX4 about 2 years ago. All was fine until a week ago when the passenger side low beam light got dimmer.
Is this a common issue? Seems like they should last a lot longer than 2 years!?
What should I replace them with? Or, is there something I should or check?
Thanks!
sjwhiteley
Kentucky
The quality of the eastern ‘brands’ tends to rise and fall with the tides. Just get another set. I had a switchback turn signal fail, just purchased another set, different brand, and went on with life.
The headlights, beams and fogs have been fine for the past 3 years or so. I believea mix of Hikari, ALLA an JDM. Whatever seemed to have good reviews at the time.
LokiWolf
Super Moderator
Super Moderator
Richmond VA
This. Cheap "No Name" off of Amazon are a crap shoot, and honestly most have actual less light output than a classic good brand Halogen. Many times they are not sending light correctly to bounce off the reflector.
ViperVette
ViperVette
Elida Ohio
Any good recommendations given it’s a new year and it’s been over two years since I bought these?
LokiWolf
Super Moderator
Super Moderator
Richmond VA
Light output is more important to me than looks, so I would go Silverstar Ultra in a regular reflector housing. It is a Halogen. Won’t last 2 years, but light output will be far superior.
Otherwise, do the same brand, or what @sjwhiteley said, and read the recent reviews.
sjwhiteley
Kentucky
That is a bulb I had thought of going with if the LEDs didn’t work out in the projectors. Just treat it as a consumable, which I think, even high output LEDs are. Even factory LEDs fail for one reason or another (albeit at a potentially lower rate), but you have to open your wallet to fix them.
apex96
PA
Check out https://www.bulbfacts.com/ for information on better quality halogen and LED bulbs in different housings (reflector or projector). Link helped me make decisions on what I wanted to install.
ViperVette
ViperVette
Elida Ohio
Thanks! I know these are consumable items but I thought they would last longer than 2 years - or, is that the the life expectancy of LEDs these days?
