Hello everyone,
First post here. As my username says I am a DIY Amateur Mechanic. Great money saver and I prefer learning how to do things, but being new I may not explain my issue correctly so please let me know if I need to clarify. So to the issue.
I have a 2001 Lincoln Navigator and while looking for reason's why my car wouldn't start without a jump I saw that the cable that run's from the Alternator (ground and plugin connector) was halfway sheared through, as it was resting against a pulley. I need a replacement part but everything I find has only the plugin connector on it with no ground wire, or the opposite end that connects to the metal posts that the battery cables connect to as well as a plugin connector (sorry no idea what it is). Any chance there is a all in one for sale that I can purchase or if I have to do it separately, can someone maybe detail the part numbers I will need so I can do that. Provided are pictures.
On this picture the cable is the one on the bottom post, all black.
https://www.dropbox.com/s/ordqe96n7i0uxe0/20150801_192917.jpg?dl=0
The opposite end that connects to the ground and the plugin connector.
https://www.dropbox.com/s/hlf62hkrk80ogg6/20150801_213500.jpg?dl=0
I removed the cable from the terminal post near the battery and disconnected it from what it was plugged into. This is just a closeup.
https://www.dropbox.com/s/1wpzlze80q4p4bk/20150801_213445.jpg?dl=0
