I'm replacing the fuse panel for the second time on an 03 EB as well. The first one the PCM was bad, and then the #203 started melting and causing all kinds of issues. The panel I have now, started connector burnout at the wiring harness because there was a 10amp fuse where there was supposed to be a 15amp, and every time the day running lights wanted to come on, the truck would stall! But until I figured it out, it was melting the plastic off the connector bolt to the wiring harness, and now it's pretty crunchy there and is failing. First pic below is showing the bolt with the plastic burned through.
I have the 03, EB, 2wd, 5.4. I'm getting thoroughly confused trying to get a fuse panel, because of part numbers. You ordered the 3L1T-14A067-AA. Correct?
What I think is the The ORIGINAL Panel for my truck is a 2L1T-14A067-AN. I am ready to order this part:
4L7T-14A067-AF. Is this going to work? Any reason to go with the 3L1T instead of the 4L7T?
I don't have any after mods, but I do have a Subwoofer that came with the truck, I have fog lights, power third seats, a DVD ceiling system that I don't use, and the 6 CD changer that has been broken forever, so I don't use. Nothing else. No sunroof, no heated seats. I know some panels support more of these items, but I don't want to get one that spesn't support what i DO have!
Also, I honestly don't know what month my truck was manufactured...the window sticker or door sticker is gone. FORD has 2 different panels available, but splits the 03 year based on the first half a year or the second half!
If you or anyone could tell me that this will 4L7T-14A067-AF will work, or what panel replacement part number I should get, I would appreciate it immensely.
