spotdog14
New noise. Comes from the front end I believe, definitely engine. Only happens at highway speeds when accelerating at high RPM's. Its a squeal, I'm thinking either idler pulley or belt tensioner.
So far the alternator is working fine, but should I look into water pump pulley?
Anything else I should check?
Thank you.
**Edit**
Figured I should add a little more information, 130k on the motor, all original pulleys as well as alternator and water pump.
Thank you.
**Edit**
