stamp11127
This is a good head scratcher & is starting to remind me of "20 Questions"...
When you first turn the key to run, do the gauges in the instrument cluster go through the sweep test?
I try to avoid using starting fluid but you could shoot a little in the airbox and try to start. If it attempts to run it will be fuel related, if it just cranks over it is spark related.
Is the theft light flashing quickly during the 15 secs you are waiting?
Have you swapped the pcm relay with another or tested it?
