Anti-Theft System ?
44Steel
Monroe La
I think I have an issue with my Anti-Theft System. Can anyone assist?
2000 Ford Expedition Eddie Bauer 4.6L with 276,000 miles
Symptoms:
Cranks but no start,
however, if I wait 15 seconds with key in on position it will start immediately. But if I crank it right away, after putting the key in, no start.
Procedures completed:
I have checked for fuel, spark, and electrical.
Verified code for EGR insufficient flow.
Pulled EGR: Found carbon build up.
Removed EGR, idle air control and throttle body, cleaned with throttle body cleaner per manufacture instructions, making sure no cleaner entered components and replaced.
Replace tubing from PCV to throttle body since it looked rotted.
Battery check:
12.16 volts sitting without key
11.94 volts with key in on position
10.71 volts when cranking
14.59 volts after starting
Crank Sensor
Replaced after back probing and did not fall between .5 and 1
Fuel rail compression: 38 and steady, 44 at initial key in run position.
Turn key on, fuel pump runs for 2 seconds and shuts off as per manufacture.
Electrical:
Checked all fuses visually and with test light.
Bench test relays with multi-meter for continuity
Inertia switch is set and never popped up, no accidents. Assume it is okay since fuel pump is running. Will check voltage to it shortly.
Engine light does not stay on while cranking.
I may have left off some tests as I have completed a lot trying to run down the issue. I am open to anything at this time.
I am leaning toward anti-theft system but I am stumped.
Let me know it you have a solution... Thanks
Sorry, forgot to mention no codes now. Did not erase any either. Using Bosch OBD II scanner.
44Steel
Monroe La
Anti-Theft issue
Forgot to mention, Smoke test. Removed vacuum from brake booster and blew smoke into it. Found no leaks or smoke coming from vacuum hoses. Not to sure if it is that accurate.
Bedrck47
Elizebethtown, PA
Suggest you check fuel pressure. When you mention that if you wait 15 seconds with key on then it starts could be due to low fuel pressure. However the fuel pump only runs for a short time unless the engine starts.
When was the fuel filter last changed and also when was the fuel pump replaced?
44Steel
Monroe La
That is one that I forgot. I replaced fuel filter last week. The family had this in Texas for the past few years. When I got it, I did most of the preventive maintenance on it. I did the fuel pressure test before during and after starting. All appear fine, ranging from 38 PSI to 44 PSI.
44Steel
Monroe La
Anti-Theft issue ?
35 to 38 PSI. I left it on and no leak down. I will try it again to be sure as an additional check.
Do you think the battery would keep it from initial start up? That is weird, because if I leave the key in the run position for 15 seconds it will start right up.
44Steel
Monroe La
Fuel pressure holding at 38 PSI.
Also checked and verified with multi-meter, all fuses in engine and passenger compartment. Some seem low at 11.6.
Fuse 20 (10A) Trailer tow stop and left turn lamp shows 34.9. After turning lights off shows 10.2. All other fuses checked out with light being turned on for lamp fuses. I know some of these wire looms are interconnected so I figured I would check them all.
44Steel
Monroe La
Not a diesel guy and keys not worn out.
Just can't believe it actually will start if I wait 15 seconds. I am puzzled by this.
Just got back from shopping. Fuel Pressure at 35 PSI battery fully charged. Still on start at initial crank, but wait 15 seconds with key in run position and it cranks right up.
Temple, Georgia
This is a good head scratcher & is starting to remind me of "20 Questions"...
When you first turn the key to run, do the gauges in the instrument cluster go through the sweep test?
I try to avoid using starting fluid but you could shoot a little in the airbox and try to start. If it attempts to run it will be fuel related, if it just cranks over it is spark related.
Is the theft light flashing quickly during the 15 secs you are waiting?
Have you swapped the pcm relay with another or tested it?
44Steel
Monroe La
I know its not fuel related because the fuel pressure is constant at 38 PSI when the truck is off. The gauges do their normal light up and sweep.
As for the starter fluid, I'm not going to spray it in the throttle body. Too many issues with that and you know it could harm some of the components.
The theft light does not flash after I turn the key to run or when I crank.
I know it will start as long as I wait for 15 seconds. I really think it is an electronic issue. I think I am going to put jumper wires on the relays and test them while they are in their proper sockets. I only bench tested them before. All the fuses seem to be normal.
I am telling you, this really has me puzzled. Even though I am a shade tree mechanic, I have been fixing my own vehicles for about 30 years. I can usually read up on things and fix them myself, but this one is a wing-dinger...
44Steel
Monroe La
Just switched out the three FOAB relays and nothing happened. Something is delaying the signal to the system. I just cannot figure it out. I am assuming one of the modules is faulty but I should be able to get a code on the OBD II scanner.
Bedrck47
Elizebethtown, PA
Just a suggestion The next time you try to start Place your gear selector in Neutral and
see if you still have the same 15 second delay.
Also has there ever bee a remote start system installed on the expy?
44Steel
Monroe La
Bedrck47
It does the same thing in neutral, have to wait 15 seconds. Not sure if it ever had a remote start. Is there a way to tell.
I do have the power distribution diagram.
44Steel
Monroe La
Not sure if it uploaded but here is 2 of 4 on the wiring distribution. It has the ignition switch on it.
  • Power Distribution 2 of 4.pdf
44Steel
Monroe La
Here are all 4 of them.
  • Power Distribution 1 of 4.pdf
  • Power Distribution 3 of 4.pdf
  • Power Distribution 4 of 4.pdf
Bedrck47
Elizebethtown, PA
Would be hard to tell if it did have a remote start at one time Unless wiring and other parts were still installed.
Where did you get your wiring diagrams from?
44Steel
Monroe La
I tried to trace the anti-theft module, but it looks like it goes up under the dash. Do you have any idea where it is located? The thing is, everything on that circuit works just fine, radio and clock. I do not have phone or navigation. I also have no idea where that generic module electronic module might be.
