Audiophile to Navigation Radio
G
Guest
Does anyone know if it is possible to change out and 2003 EB Audiophile system with the stock EB navigation unit? What needs to be done, just change the 6 disk head unit with the Navigation Unit? Is it the same wiring harness? Also, what parts are needed, Head unit, antenna, cd's....
Any help would be great!
Thanks,
Jason
elbuencarlos
EL Paso TX
First - The harness it's not the same, you will need a harness converter.
Second - You will need also an additional GPS antenna that must be wired separately.
Third - The factory navigation radio came in 2.5 dim size, so probably you need to modify also your dash.
Important: you need to take care that the harness converter connects properly the speed and reverse sensors.
