Auto 4WD to 2WD
Elroy303030
Branson, Mo.
I was woundering if there was a way to switch the auto
4WD to a 2WD, Auto, 4HI, 4Low? I read on here that you
can cut the brown wire underneith to turn it
off, but I dont want to turn it off all the time.
AvroAero
Toronto, Ontario
If you want run a switch into the cab that closes or open the brown wire circuit and you'll be able to disable A4WD. You can't really use another switch that has 2WD on it since those switches use variable resistances.
chuck s
My '07 is setup this way. 2H, 4A, 4H, 4L on the switch. I'm not sure how this is wired, but it works. Rarely leaves 2H in my driving. 4A scrubbed the tires on my Explorer.
-- Chuck
AvroAero
Toronto, Ontario
No, if its not stock then no. The switch works on different resistances to select different drives. If I'm wrong find yourself a switch with 2h on it and plug that in. Otherwise its to hard to bother.
Dom neufer
Bloomsburg
I wouldnt go cutting any wires when all you haver to do is remove a fuse and its going to be in a4wd anyway all the lite brown wire does is stop the transfercase from going into a possie type of mod 30% of your power is going to the front wheels either way wire cut or not
firefighter407
It's true changing out the switch doesn't do anything, even thought the wiring colours are the same. Ithought it would be an easy way and not cut the wire
thedon
reno, nv
everyone i have talked to say they get 16 mpg or higher, i only get 10 mpg and the only difference i can tell is mine is awd. instead of 2 wheel/ 4hi 4 lo. has anybody made the wire change to 2wd and gotten better gas milage. what kind of milage do you get on your expeditions?
