nybandit
Hello all, searched threads for this and only found fixes for older models. I have a 2010 and the camera works fine, the backup sensor "on/ off" shows in the cluster as on. It also shows as "on" when I put it in reverse. When I select for it to go "off" (in an attempt to toggle on/off then on again) the selector <> goes away. I ordered a new backup speaker on ebay for $10 hoping this is the issue.
1. Where is the speaker located?
2. If the speaker is not the issue, what should I run down next?
Thank you all in advance!
