Battery light
Sport06
Lander Wy
Battery light on,Charging system checked nothing wrong,has anyone else had this problem.If you know what was wrong,what did you do to fix it. I'm new to this forum thanks for the add
Bedrck47
Elizebethtown, PA
What year is the Expy?
How old is the battery?
How did you check the charging system/ Or who tested it?
What is the voltage at the battery with engine off and key out?
What is the voltage at the battery with the engine running at idle?
What is the voltage at the battery with engine running at about 1500 to 2000 RPM's
kyle_in_rure
TN
Is the light on constantly or does it only come on under certain conditions?
stamp11127
Temple, Georgia
If there wasn't anything wrong the charging light wouldn't be on. Whom ever told you the charging system is fine is mistaken.
The electrical current has two paths it can take, normally it flows the path that doesn't include the idiot light. When there is a problem on the normal path it flows through the other path which includes the idiot light letting you know your battery isn't being charged.
