Beep Beep
Yupster Dog
Super Moderator
Super Moderator
Is there any way you can disable the horn beep beep when I close the door with the motor running? My neighbors would appreciate it at 4am. My expy is a 2020.
Put double beep in search box top right of this page and you will find many threads on the subject.
Do you know what FORScan is? It can help you remove the double honk and much much more.
There is a FORScan section but here is the sticky from there below that helps explain.
https://www.expeditionforum.com/threads/forscan-tweaks-2015.32082/
Yupster Dog
Super Moderator
Super Moderator
What was the 2nd? Just out of curiosity...
If you want a member to get an alert, you must quote them like I have you.
You also can mention them by putting the @ symbol in front of their name and that also will give an alert
@rslynes
Welcome to the forum
mdexp
maryland
I never tried Forscan on my 2019 but also hated this! Definitely a nice feature of the new model - this can now be turned off in the settings.
sharprd65
