Bleeding brakes
Solefly87
South Carolina
What's up guys!! It's been quite a while since my last post. The big machine is still running like a champ with 265xxx miles on her.
Sooo. What I'm working on now is my brake calipers. While changing out my brake pads I noticed one of the seals around the Pistons were cracked and leaking a little. Unfortunately I had to continue the process and drive home like that. The car started driving fine, then it started to feel like I was pulling a boat! The car would shake a bit while driving at high speeds too. So I have two new brake calipers for the front. I've seen plenty of videos and read many threads on how to change those.
My only question is. How do I bleed the brakes? -__- lol is there any thread someone can guide me to or a even better, a video on how to do it on a 2000 expy 4.6 XLT. should I bleed them all or just the front two? I am doing it with a friend so i am not using a (bleeder tool?)
I have brand new copper washers for the brake hose too. Brake hose seems to be intact. So I'm not going to mess with it just yet.
Once again, thank you guys. I wouldn't have been able to get the beast at 260xxx without you guys.
**one more Quick question, my buddy says that if you do not have the brake reservoir cap off while you change your brake PADS, you can mess up the master cylinder and brake hoses, is this correct? If so. When should I remove and replace the reservoir cap while changing out my brake calipers. Thanks again!
docraymund
philippines
Start with the rear wheels right side first, then left. After that move to the front wheels. If the brakes still feels spongy, you may have to bleed the abs with a scan tool. Yes, remove master cylinder cap to add brake fluid as you go along.
Bedrck47
Elizebethtown, PA
Page 1 of 2 Copied from the 2000 Ford Service Manual
Bleeding
Special Tool(s) Worldwide Diagnostic Tool (WDS)
418-F224,
New Generation STAR (NGS) Tester
418-F052, or equivalent scan tool
NGS Flash Cable
418-F120 (007-00531) or Equivalent
Master Cylinder, In Vehicle
WARNING: Brake fluid contains polyglycol ethers and polyglycols. Avoid contact with eyes. Wash hands thoroughly after handling. If brake fluid contacts eyes, flush eyes with running water for 15 minutes. Get medical attention if irritation persists. If taken internally, drink water and induce vomiting. Get medical attention immediately.
CAUTION: Do not allow the brake master cylinder reservoir to run dry during the bleeding operation. Keep the brake master cylinder reservoir filled with the specified brake fluid. Never reuse the brake fluid that has been drained from the hydraulic system.
CAUTION: Brake fluid is harmful to painted and plastic surfaces. If brake fluid is spilled onto a painted or plastic surface, immediately wash it with water.
NOTE: When any part of the hydraulic system has been disconnected for repair or new installation, air may get into the system and cause spongy brake pedal action. This requires bleeding of the hydraulic system after it has been correctly connected. The hydraulic system can be bled manually or with pressure bleeding equipment.
NOTE: When a new brake master cylinder has been installed or the system has been emptied, or partially emptied, it should be primed to prevent air from getting into the system.
Disconnect the brake master cylinder outlet tubes.
Install short brake tubes with ends submerged in the brake master cylinder reservoir and fill the brake master cylinder reservoir with High Performance DOT 3 Brake Fluid C6AZ-19542-AB or equivalent DOT 3 fluid meeting Ford specification ESA-M6C25-A.
Have an assistant pump the brake pedal until clear fluid flows from both brake tubes without air bubbles.
Remove the short brake tubes and install the brake outlet tubes.
Bleed each brake tube at the brake master cylinder as follows:
Have an assistant pump the brake pedal and then hold firm pressure on the brake pedal.
Loosen the rearmost brake tube fittings until a stream of brake fluid comes out. Have an assistant maintain pressure on the brake pedal while tightening the brake tube fitting.
Repeat this operation until clear, bubble-free fluid comes out.
Refill the brake master cylinder reservoir as necessary. Repeat the bleeding operation at the front brake tube.
While the assistant maintains pressure on the brake pedal, tighten the brake tubes.
Four Wheel Anti-Lock Brake System (4WABS)
NOTE: This procedure must be performed if the 4 wheel anti-lock brake (4WABS) hydraulic control unit (HCU) has been installed new.
NOTE: One conventional pressure bleed cycle consists of advancing the brake pedal to its depressed position, opening the disc brake caliper bleeder screw, allowing fluid to be released into the waste container, closing the disc brake caliper bleeder screw and releasing the brake pedal.
NOTE: Performing the NGS program routine drives entrapped air from the otherwise inaccessible lower section of the 4WABS valve into the upper sections (accessible by bleeding the brakes). Subsequent bleedings remove the air from the system.
NOTE: Add recommended brake fluid as necessary throughout the procedure.
Connect a clear waste line to the RH rear disc brake caliper bleeder screw and the other end in a container partially filled with recommended brake fluid.
Loosen the RH rear disc brake caliper bleeder screw until a stream of brake fluid comes out. Have an assistant maintain pressure on the brake pedal while tightening the RH rear disc brake caliper bleeder screw.
Repeat until clear, bubble-free fluid comes out.
Tighten the RH rear disc brake caliper bleeder screw.
Repeat Steps 1, 2, 3, and 4 for the LH rear disc brake caliper bleeder screw, RH front disc brake caliper bleeder screw, and the LH front disc brake caliper bleeder screw.
NOTE: Go to the help menu in the scan tool.
Connect the scan tool DCL cable adapter into the vehicle data link connector (DLC) under the dash and follow the scan tool instructions.
Repeat the conventional bleed procedure as outlined in Steps 1 through 5.
If the brake pedal feels spongy, repeat the scan tool service bleed procedure.
Gravity
Fill the brake master cylinder reservoir with High Performance DOT 3 Brake Fluid C6AZ-19542-AB or equivalent DOT 3 fluid meeting Ford specification ESA-M6C25-A.
Bleed the rear disc brake calipers.
Place a box end wrench on the RH rear disc brake caliper bleeder screw.
Attach a rubber drain tube to the RH rear disc brake caliper bleeder screw and submerge the free end of the tube in a container partially filled with clean brake fluid.
Open the bleeder screw and leave open until clear bubble-free brake fluid flows.
Repeat for LH rear disc brake caliper.
Tighten the rear disc brake caliper bleeder screws.
Bleed the front disc brake calipers.
Place a box end wrench on the RH front disc brake caliper bleeder screw.
Attach a rubber drain tube to the RH front disc brake caliper bleeder screw and submerge the free end of the tube in a container partially filled with clean brake fluid.
Repeat for LH front disc brake caliper.
Tighten the front disc brake caliper bleeder screws.
Bedrck47
Elizebethtown, PA
Page 2 of 2 Copied from the 2000 Ford Service Manual
Manual
Place a box end wrench on the RH rear disc brake caliper bleeder screw. Attach a rubber drain tube to the RH rear disc brake caliper bleeder screw and submerge the free end of the tube in a container partially filled with clean brake fluid.
Repeat Steps 1, 2, 3, and 4 for the LH rear disc brake caliper.
Place a box end wrench on the RH front disc brake caliper bleeder screw. Attach a rubber drain tube to the RH front disc brake caliper bleeder screw and submerge the free end of the tube in a container partially filled with clean brake fluid.
Loosen the RH front disc brake caliper bleeder screw until a stream of brake fluid comes out. Have an assistant maintain pressure on the brake pedal while tightening the RH front disc brake caliper bleeder screw.
Tighten the RH front disc brake caliper bleeder screw.
Repeat Steps 6, 7, 8, and 9 for the LH front disc brake caliper bleeder screw.
If necessary, bleed the brake master cylinder. For additional information, refer to Bleeding in this section.
Pressure
NOTE: Bleed the longest line first. Be sure the bleeder tank contains enough specified brake fluid to complete the bleeding operation.
Clean all dirt from and remove the brake master cylinder filler cap and fill the brake master cylinder reservoir with the specified brake fluid.
NOTE: Master cylinder pressure bleeder adapter tools are available from various manufacturers of pressure bleeding equipment. Follow the instructions of the manufacturer when installing the adapter.
Install the bleeder adapter to the brake master cylinder reservoir and attach the bleeder tank hose to the fitting on the adapter.
Open the valve on the bleeder tank.
Loosen the rear disc brake caliper bleeder screw. Leave open until clear, bubble-free brake fluid flows, then tighten rear disc brake caliper bleeder screw and remove the rubber hose.
Continue bleeding the rest of the system, going in order from the LH rear disc brake caliper (2552) to the RH front disc brake caliper (2B121) ending with the LH front disc brake caliper.
Close the bleeder tank valve and remove the tank hose from the adapter and remove the adapter.
Fill the brake master cylinder reservoir and install the brake master cylinder filler cap.
Master Cylinder, Bench
Support the brake master cylinder body in a vise and fill the brake master cylinder reservoir with specified brake fluid.
Use High Performance DOT 3 Brake Fluid C6AZ-19542-AB or equivalent DOT 3 fluid meeting Ford specification ESA-M6C25-A.
Install short brake tubes with the ends submerged in the brake master cylinder reservoir.
Slowly depress the primary piston until clear fluid flows from both brake tubes, without air bubbles.
Remove the short brake tubes.
S
Solefly87
South Carolina
Thanks guys for all the help. So I started the whole bleeding process. But when I got to the front driver tire, the bleeder valve is stripped!! I can't get it off! What can I do to try and take it off to replace it? Please help
Bedrck47
Elizebethtown, PA
Before you take the above advice.
Check on youtube as there are many videos on bleeder valves.
search for the below
A method for removing a seized brake bleeder valve (youtube)
Hopefully you will find a method that will work for you
Temple, Georgia
Use a manly pair of vise grips, soak the bleeder screw with PB Blaster overnight, then try to back the bleeder screw out some. Should you be able to back it out, it is a replaceable fitting. Most decent auto parts stores with have them. Should it be stubborn then the quickest alternative is to replace the caliper.
reece146
ON, Canada
As above.
I've found that banging one of those square easy-outs into the exposed hole after snapping off the tip can work if you get lucky with the penetrating oil.
If you are really stuck then you can drilling it out just shy of the threads; it's soft metal so doesn't take much. Then you can try to knock/pry the remains out. If the drill makes a lot of mess inside the caliper you may want to disassemble, clean and rebuild at the same time.
HTH
S
Solefly87
South Carolina
Got it!!
First off. Thanks to everyone again.
I really did t want to spend the money on a new caliper since this one wasn't in bad shape. My buddy who sold me the car told me he stripped it the first time while taking it off. He managed to get it off, and instead of switching it out with a new one he put it back in.
Thank you bedrck for the YouTube idea. I originally started looking there but wasn't finding anything on expeditions specifically.
Out of all the options I saw, I decided to hit it with the torch. Got it hot, and to my surprise an 8mm fit nice and snug on it, and I got it to loosen.
Finally finished my brake job and bleeding.
Thanks again for all that
ghaniabdul
indonesia
You will have to replace the whole caliper body.
