blend door where?
svfetter
Louisville, KY
2011 XLT with dual zones. With AC on driver side gets cold but passenger side will not change from hot. I know about the one behind the radio but doesn't that one control driver side. Where is the one for the passenger side? Thanks.
Bedrck47
Elizebethtown, PA
I don't have the manual for the 2011 year but I do for the 2010 and looking at the prints the passenger side temp actuator is located above the drivers side temp actuator
Looks like it is on top of the housing
Hope that helps
S
svfetter
Louisville, KY
Are you talking about the one behind the radio? That one is labeled rh unit, I guess when standing in front of truck. They show the lh unit on page 412-01-46 of the 2011 manual. But I am having trouble locating where that is.
Bedrck47
Elizebethtown, PA
Left hand is drivers side Right hand is passenger side
Since you have the manual go into the wiring diagrams and look at the section for the Automatic Climate Control System Section 55
Then look at page 55-2 Look on the right side of that page you will see the wiring for the Temp blend doors there is a reference to page 151-45 Look at that page it may give you a better idea
S
svfetter
Louisville, KY
Yes, I have verified that the one behind the radio is the one that controls the passenger side. Fix should not be too bad. Hope I never have to replace the one on the bottom.
I have known that these have a history of problems. I have always limited how much I change the temp. Once for winter and once for summer and it still got me
ManUpOrShutUp
PA
I haven't done the one behind the radio, but word is that it takes less than 1 hour if accessed from behind the radio. The one on the bottom is a serious ***** to do properly, but I did see a YouTube video in which the guy removed the trim panel and then cut a hole behind the trim panel, which made the job go pretty quickly. As much as I hate to fudge things like that, I think I could live with it considering the labor savings and fact that the shortcut hole will be hidden behind the trim.
Denethor
Durham, NC
Just a question since I don't see it in your posts. Do you get the clicking noise in the dash when changing from hot to cold on the passenger side or just that it never switches? The actual or could have just failed, without the common tooth slipping noise, but it could also be something fell in to the vents and is blocking the blend door from moving properly.
S
svfetter
Louisville, KY
I heard the dreaded clicking about a month ago. None since then and passenger side temp wont change. So I think maybe a tooth broke and is jammed. I am going to make sure the blend door moves freely before I put in the new actuator.
Paul Foy
Fort Wayne, Indiana
I just changed my passenger one out this weekend on my 2010 Limited 4WD. It is located behind the radio. Cost about $21 with my military discount from O'Reilly's. The hard part was squeezing my right arm through the metal brackets to get to the back screw from the glove box compartment. The new part was much thicker which made it even harder to screw in because you could not see the screw head. Did it by feel only. I have numerous cuts on both hands but it was worth saving all that money the dealer would have charged me.
S
svfetter
Louisville, KY
I ordered the wrong part. Correct one (I hope) will be here in a couple days. Amazing how many configurations of these things there are. I had to get the part number off the one out of the truck and even then found that the part number has now changed. Seems like Ford tries to make things as complicated as they can some times. Had very little issue actually getting to it though.
Denethor
Durham, NC
Ask a tiny neighborhood kid (or your own if you have them) or wife to reach up in there, their arms are smaller :0) but I was the same way, many small cuts on the forearm. I have large arms though so I thought it was just me...
S
svfetter
Louisville, KY
Got er done. Piece of cake. I did follow some additional instructions on one of the YouTube videos.
Remove number 15 fuse before beginning. Replace when complete. Turn ignition key to on position for one minute or more which will recalibrate system. Started it up and everything was back to normal. Worked great.
