djewing
2001 Expy 4x4, 4.6 (stock electrics, no aftermarket alarm etc)
Yesterday I couldn't get my car started.
The "theft" light was blinking rapidly and wouldn't stop, the engine would crank fast (good battery) but would not start. I didn't want to kill my battery so I looked online and tried the several solutions I found to no avail. (I heard everything from the key being bad to the PCM needing to be replaced) I then called AAA for a tow but was able to get it started instead.
Thankfully, the cure for me was pretty simple, maybe it will be for you too:
If you experience the same problem try checking in the fuse box in the engine compartment for dirty or corroded fuses. Also, there are 3 diodes at the front end of the box. One of those diodes is the "PCM Power Diode" and is the closest to the fender side of the fuse box. I was able to pull out, clean the sockets with contact cleaner and reset the mini fuses and diodes and the problem went away. One of the mini fuses (#2-30amp) is for the "PCM Power Relay". So I suspect the problem either being the diode or that particular fuse. I noticed that all the fuses/relays were somewhat corroded and dirty so I just pulled all of them and used contact cleaner to clean the sockets and reinserted new mini fuses. I inspected the maxi fuses and found they were all in decent shape so I cleaned and reinstalled them as well as the relays to hopefully prevent any other trouble down the road. *also* just an FYI: none of the fuses were blown. All were good, just had dirty legs and sockets.
Just thought I'd share. Hopefully this will help someone else.
