Brown Wire Mod: How To
Mediamonkey11
Enumclaw, WA
Ok guys, I searched and could not find anything as far as a write-up for our Expy's relating to the "Brown Wire Mod" that was anything other than "cut the brown wire near the t-case shift motor". I wanted to retain the A4WD feature so I set out to make it work.
The purpose of this mod is to be able to disable the A4wd so as to have 2wd like on the 97-99 Expeditions have. Just to clarify, with the toggle switch off, you still can engage 4wd hi and low, but you won't have A4wd. I like the idea if retaining the A4wd, it hate not being able to control it, not to mention the front end drag when making a tight turn.
Parts needed:
30a Toggle Switch
5-6ft of wire (2 strand wire, or 10-12ft single, cut in half)
Various Connectors of Choice
First you have to find what wire we're going to be interrupting the signal of.
Finding the wire in the truck was the hard part, but here is the wire in question looking under the truck. This is it on the motor side of the connector:
And this is the same wire on the truck side of the connector:
Here's where it enters into the body:
--------The above pictures are for reference only, not necessary to identify unless you want to verify its the correct wire inside the can before cutting it which is what I did--------
Don't make the same mistake I almost did and think it was the big brown wire in this harness that runs along the drivers side:
The harness that the wire we want is located in comes through the floor under the drivers seat, then makes a turn for the above harness so one would assume its be in there, nope, I checked!
I did have to lift the drivers seat out of the way because the harness enters the body directly underneath it and it is accessible through the hole in the carpet where the rear floor heater duct pokes through as seen here:
So, now is the time you get to cut. Cut the wire and splice your new wiring for the switch in line with the brown wire in the above picture. I used make and female spade connectors just in case I ever wanted to revert back to stock, but you could certainly use butt connectors and be fine. Here's a pic with the wire spliced in:
So now run your wire under the carpet toward the front of the truck. I ran mine in the channel where the console meets the floor so I wouldn't have a lump under the carpet. It should come out here:
Make sure to tuck the carpet back underneath the heater duct for optimal rear seat passenger comfort:
Now remove the stereo bezel that houses the 4wd rotary switch.
Then run the wire up through the dash (I used a stick poked through the hole the 4wd switch wires come through, and ran straight down to where the wire was in the above picture, then taped the wire to the stick and pulled it through) and zip tie it in place so it doesn't fall back through when you put the bezel back into place:
Lastly, find a place you want your switch (I wouldn't suggest to mount it where I did because I had to snip off the lower mount for the vent above the switch due to the retaining nut for my toggle was too big and needed room. Thank goodness ford put the two tabs on the side or it would be flopping all over in there!) and wire it up. I used a switch with an indicator so I needed a ground, I found one in the climate control harness pictures below, but any ground will work.
I didn't get a final pic yet, but I will.
Here're a couple test videos, interestingly enough (I was not expecting this), the led will be on all the time when the switch is on (enabling A4wd) but will be slightly dim, and will get bright when the clutch activates. I can see it happen while turning at full lock and when traction is lost. See videos below:
http://i132.photobucket.com/albums/...088E10D8-227-0000001A7A4513FF_zps18d7019b.mp4
http://i132.photobucket.com/albums/...E94C74EA-227-0000001B83663CF4_zps6350d955.mp4
***If someone could please direct me as to how to imbed video, that'd be sweeeet***
Overall I love the mod, NO MORE FRONT END DRAG WHILE TURNING!!! It was driving me nuts while parallel parking making me think I was rubbing against something. But, that's gone now, yah!
Sadly, she doesn't have enough power to burn out, but I do get a chirp off the line now!!
I'm also pretty stoked I can see when it engages A4wd now, seems cool to me for some reason.
Lemme know if y'all have any questions!!
bcmaxx
trail,b.c.
nice work , but you did that the hard way! You can just remove the passenger kick panel access, snip the brown wire at the connector, add 3 ft of wire and a switch there, took about 15 minutes. I mounted the switch to the back of the glove box ( couldnt find a switch I wanted )
Mediamonkey11
Mediamonkey11
Enumclaw, WA
Good to know. Can you post a picture of where you intercepted the wire so people can reference to that as well? That is why I did this because I couldn't find anything actually referring to our Expy's. I saw some posts regarding getting to it through the kick panel but I also saw that peole said there were multiple choices of wires there, which is why I decided to follow it for myself :)
I still for the life of me cannot understand how the wire gets over to the passenger side from where it enters the truck unless it goes toward the backa nd then all the way around. Makes no sense!
bcmaxx
trail,b.c.
hi! Brown wire mod help, 2001 navigator - Ford Truck Enthusiasts Forums and go to post #12, its that brown one in the arrow. I have confirmed it cuts power to front, and switching to 4h, 4lo over rides and you still have full 4wd operation :)
Mediamonkey11
Mediamonkey11
Enumclaw, WA
That's what I was looking for when researching this mod. Couldn't find it unfortunately :-(
Either way, at least there're multiple options!
kaz8772
kansas city
I have tested pulling the fuse to see if it rid my expy of the steering shake. It worked, so BWM will be done tomorrow. Does the mod switch in the off position disconnect the A4WD, but leave the 4HI and 4LO working without flipping the switch? I was thinking of running this using a relay to control it from the factory switch.
bcmaxx
trail,b.c.
Yes normal operation otherwise . I put the switch in the glove compartment. Ill switch it to awd for the wife this winter. So yes awd disabled 4lo and 4hi has completely normal operation
whowey
Illinois
Does anyone know how many amps actually run through that wire???
I sincerely doubt that it is anywhere near 30a running in what looks like 14 gauge in the pictures.
I ask, as I would love to use a small latching push button switch on the dash for this. But switches able to handle 30a are much larger and uglier than I really want.
toms89
technical advisor
MD
Nice write up!
This thread should be made a sticky for ease of future reference.
kaz8772
kansas city
You could use the low current rated switch to run a 30A relay in either case. Just use the switch to provide ground on either 85 or 86 and fused 12v to the other, then connect the two ends of the brown wire to 30 and 87A (the middle connection). This will connect the wire together when the switch energizes the relay.
whowey
Illinois
I realize that I could do that. I'm not sold on the idea of adding another layer of electrical stuff to troubleshoot in case of problems. Like I said though, I really doubt there is anywhere near 30a running through that wire. That is alot of 12v DC current to be going through there.
bbiljah
daytona
If you just want to cut the wire underneath and tape it, what one do you cut?
Mediamonkey11
Mediamonkey11
Enumclaw, WA
Either wire in the first two pictures will do. They're he same one, just on either side of the connector at the shift motor.
bbiljah
daytona
Pedition2000
North Carolina
What if I don't want to retain the AWD feature but keep 4HI and 4LO, do I just clip the wire and leave out the switch part?
