98eb5.4
front diff is shot, 4X4 never worked worked in the last 5 years & i'm getting to it now
a few years ago, i noticed the pax side inner axle had lotsa play on it, in that you could pull it away from the (#15 top pix) diff extension housing (~ a foot long) piece on that side of the diff, quite a bit, like it wasn't secured properly, this when it was all attached in the front, cv axle & everything,
started to get some random serious noises there so started by pulling the pax side cv axle, then, discovered at some point a crack in the (#15 top pix) extension housing at the bottom corner where the flange bolts up to the diff by 4 bolts
it ended up coming off in 3 pieces, i figure the securing circlip for the inner axle at some point came off/broke, allowing excessive left right movement of the inner axle eventually stressing & cracking/breaking the housing where described,
so got a used front diff but some parts were missing that are shown & described well in this post
4wheel drive, front end not engaging (?) - F150online Forums
parts missing (or not there) on the one i received are (1st or top pix in link)
#10
#24
#25
then in the second, or bottom pix
#18
anyone know if part #18 (lower pix) can be added from the outside? without taking off that foot long pax side inner axle extension housing (#15 top pix)?
looks to me like part #18 is secured by pin #17 (bottom pix) & housing part # 15 (top pix) has to come off to secure the pin for #17, #18 & #13 (front axle drive shift fork)?
"In the top picture #10 pushes #25 and that ( look at bottom Picture ) pushes #13 and that slides #14 over #15 and (top picture) #11 to lock them together."
#10
#24
#25
#18
