Cam Phasers or Turbo Wastegate Rattle?
Bmac1955
Southern Cali
Just got back my 2019 expedition for Cam Phaser repair along with #21B10 reprogram and 21N03 repair. Here is a list of campaign parts used to repair Cam Phaser repair.
Rossue
SLO CA
Took my 6/19 build XLT in for a battery issue and was reminded of the software "recall". Wan't going to do it based on reading here as I haven't had any problems fortunately, however the service advisor mentioned that if I did not do the software flash before a date in February I would not get the extended warranty from Ford for this issue- to 70K or the pro-rated charge thereafter for repairs. I let them do it.
StephenPT
Portland, OR
Does anybody have a picture or instructions that could lead me to the wastegate actuator? I'd like to try this.
Here's a video showing the part of the turbo that causes the rattle.
Here's a video showing where it is on the vehicle.
S1N2W1N
indiana
Sorry to join in on this so late I’m new to the Expedition club. My recent 2017 Lariat super crew had the cam phasers go bad as well. They also changed out the timing chain as well. “Since they were already there”. Is that a common repair on these same engines? On the f150 the dealership insisted on trying some factory download to fix it. It did nothing as well. After the fix with phasers and timing chain it went away. I traded it for my current super duty headache.
My question is, will the cam phasers that the dealership is replacing on their dime be my only problem, or should I be asking the service director more questions such as timing chain replacement or whatever else is directly involved?
bbenz3
I'm so over this whole cam phaser thing and the wastegate thing. I really don't care anymore. Fix it, don't fix it, let it blow up, whatever. I'm also done with Ford. Won't buy another for a LONG time if ever. They have turned their backs on all of us, so screw them.
Interestingly though.....I parked in the street the other day after running some errands because I wanted to blow out the garage and the driveway real quick. Walking back to the truck (which I left running and the engine was warm) I heard a continual ticking. Some what fast, tick, tick, tick, tick, tick. Any guesses on what that is? Almost like the low oil or bad valve tick from the 70's. Thoughts?
Most likely that is just the your fuel pump.
NukeLife
Charlotte
I’m a little confused.
From your post, it looks like you had the cam phaser job done on your F150, then traded it for a super duty.
So your cam phaser worries are over. This is a Ecoboost engine concern.
But yes, a cam phaser replacement job should always include the timing chain, and slides and a host of other hardware. It is all listed in the technician’s repair guide. He wasn’t doing you any “favors” out of the goodness of his heart. He is required to replace all those parts per the recall.
If he wanted to really help, he’d replace the damn top of the engine due the fvcked up design.
S1N2W1N
indiana
Ok, that’s good news to me then. Yes that happened on my f150. I was just kind of hoping that it was the same problem. I only know of it strictly due to cold starts. I would have never thought that mechanic was doing me a personal favor. Those just happened to be his words of choice when he explained what was changed. He did not mention any other things to be changed with it. Probably because it’s none of my concern what actually had to be done to completely fix the problem. I’m just thankful it’s not on our dime.
S1N2W1N
indiana
I also have a 2019 xlt max that recently had the cam phaser work done. There is still an annoying rattle that the Ford techs told my wife and I that was the Wastegate. they can’t fix the Wastegate under warranty unless there is a check engine light / DTC. Is there any Ford techs that can confirm that this is the standard protocol with this issue. At this point we feel like we have gotten ****** on this so called certified pre-owned vehicle. Secondary note: the cam phasers was on the list of the things that were to be fixed. It blows my mind that you literally have to get an engine light for them to actually fix something. But if that’s the case at least I know not to take to my local dealer to try and have them address the issue. We just want the rattles gone like we were promised. We were also told that there are 3.5’s out there that start having these issues before the 1st breakin oil change.
SyndicateZ
Mass
Hey! I am have the Same exact issues as you! 2019 expy Stealth. I have a rattle on cold start that lasts about 3-5 minutes. I know its the driverside turbo wastegate as I can hear the actuator adjusting with the sound and then goes away after that final adjustment and it quiet like magic...I also get a rattle when I blip the throttle on accell and decel. I have an appointment with a ford dealer and hopefully they dont tell me that these are just "noises" and not fix it. Im still under powertrain warranty at 58,600.
That said, I can almost guarantee that if I was not under warranty they would tell me I NEED to replace the turbos,Etc (at my expense lol)
Bmanxx13
Arizona
I’ve learned to just deal with the WASTEGATE rattle. As long as the damn cam phaser rattle doesn’t come back (been about 40k miles since replacement) then I’m happy. I was so embarrassed starting my vehicle early in the morning when I had the issue. It was so loud, lol.
dbozian
naples Florida
I'm so sorry for starting another thread on this topic... Ever since I bought by 2019 Expedition max there has been a rattle from the engine compartment on cold start. I have literally spent hours reading these forum posts and watching YouTube videos. From what I learned, I self-diagnosed it as being wastegate rattle. I'm totally not qualified to diagnose, but there you go.
Anyways, I took the vehicle to my Ford dealership today to have the failed center brake light replaced under warranty, and I mentioned to the guy that there's a rattle in the engine compartment on cold start; if they have it all day and start it after it has cooled down, can they check it out? He said right then it's cam phasers. I asked how they know that the rattle isn't the electronic turbo wastegate, and he said that isn't a possible rattle, but "cam phasers go out on all these vehicles, so I'm sure that's what it is". He then called me an hour later and said the rattle is definitely from cam phasers, and he wants the vehicle for several days to replace them. Odd since the vehicle didn't even have time to cool down enough to replicate.
It's a bummer how experience can vary from one dealership to another; some complain that their dealer refuses to fix the problem, while mine is so anxious to jump on it. I'm thrilled they want to fix my problem, but my question is: HOW DOES ONE DETERMINE WHETHER THE RATTLE IS CAM PHASERS OR THE WASTEGATE? I'd love to feel confident that it has been properly diagnosed rather than diagnosed based on assumption because I really don't want the engine opened up if it's a different issue, and the guy I spoke to did not instill much confidence for me.
I need the vehicle tomorrow so told them not to start the work and will schedule it for after boating season ends when I don't need the vehicle. He told me that's a terrible decision because they could go out any minute and leave me stranded. I thought that was odd as well because from what I've read in other posts, Ford doesn't even think it's a problem that needs fixed.
Anyways, here's a sound clip but not very good... The rattle in this clip sounds so much worse than it actually is. Standing next to the car you only notice it if you're listening, and it just sounds like an exhaust hanger is loose.
https://drive.google.com/file/d/10TqS3epotFVIQo_Lv3-puTUzAL5RyKfg/view?usp=sharing
RickDenverRealtor
Denver, CO
I am embarrassed by it too... like people are looking at me like I am driving a broken car. Sucks.
