HarveyCat
Can damage to the wire harness that is run inside the wheel well cause the same issues as the GEM module problems?
So last year in the summer my wheel well wiring harness came loose and rubbed up against my tire. My mechanic found it and said he taped it up -- and all then was fine. Last winter I started to have an issue with my blinkers not working, as well as my ABS light and 4X4 light coming on all at the same time. I replaced the multifunction switch on the steering column (blinkers - wipers - etc) -- but still when driving in heavy rain or snow these issues return. My mechanic saw online that windshield leaks in F150s can cause the G.E.M. module to fail and cause such problems -- but I looked at mine under my dash -- with a mirror and a light -- but I saw no signs of corrosion -- also I never get the classic water spot on the drivers floor symptom. Anyway -- I got the right replacement GEM module so that can be replaced without the dealer needing to program it.
BUT I got to thinking -- maybe it is just these damaged and taped up wires. Any thoughts anyone? I will inspect these wires as soon as the snow here in Hoboken stops.
BTW -- I have 2002 Expedition -- but it looks the same as the F150 -- the wiring harness was foolishly run in the wheel well by FORD... Here is a picture of the wires --
