CAN'T WAIT for THURSDAY!!!
CertusExpo
Customizing trucks since I was 7 with my Legos
Fort Worth, TX
I got my new 30" Rigid LED bar today!! It'll go nicely with the LED headlights :flamingdevil:
CertusExpo
CertusExpo
Fort Worth, TX
I'm going to install it high up behind the grille so it's hidden and protected from easy theft
(Superimposed in pic)
And, with a little trimming.
106322
These should fit in place of the stock fog lights!
106322
Gruz7
North Smithfield, RI
Nice its gonna look good man I was planning on a light bar too for the roof though
CertusExpo
CertusExpo
Fort Worth, TX
Update with pics
I haven't installed it yet. Had stuff come up on my days off and then, due to weather looking to switch to winter fast. I put my drilled/slotted rotors and caliper paint job on the To Do NOW list.
I did manage to snap a few 'test run' pics of the lightbar sitting on the fan cowl.
Here are a few highlight pics but I plan on writing up a complete How To with ALL the pics I took of the process.
CertusExpo
CertusExpo
Fort Worth, TX
Thanks!
I went ahead and uploaded the brake upgrade pics to an album in my profile if anyone is curious.
AggieExpo
Aggielnd
Well let me know how it holds up. It being plasti dip i wonder how it holds up to heat?
Sent from my SM-N900V using Tapatalk
CertusExpo
CertusExpo
Fort Worth, TX
They (Plasti-Dip) called me back and they advised me of the exact temperature extremes it is tested for but... called me WHILE I was doing the brakes so it was moot but if I remember right, up to somewhere in the 400 degree range.
I've used Plasti-Dip before for rims and trim. I have even used it for blacking out a tailpipe and it handled that heat just fine. I don't expect the calipers to heat more than a tailpipe although I could be wrong.
I will updated as needed.
AggieExpo
Aggielnd
Cool. I will give that a try when i do my breaks.
CertusExpo
CertusExpo
Fort Worth, TX
The key is the prep of the dirty calipers. I used both brake cleaner and caliper cleaner that I found in the automotive paint area along with scrubbing with an old toothbrush.
In hindsight (and if I had thought about it before) I should have done a pre cleaning by soaking with a HD pump spray household degreaser, rinsing and repeating a couple times and then following up with the brake cleaners.
The inherent nature of Plasti-Dip is that it seems to want to merge and adhere to itself so as long as it's layered in several nice coats it should stay conformed to that shape.
I had at least 6 main coats with more layered on the sides/edges.
