I just felt my sphincter muscle pucker lol
$399.
http://teamrxp.com/products/2011-2014-ford-f150-ecoboost-complete-kit-factory-fitiings
$399.
My thought on the $50 can that you show is this.... it looks like it has the same ball valve that’s used on my RXP Can, which is a quality valve, and the rest of the cans parts look to be ok also as far as quality goes. What the kit is lacking is the factory ford hose connectors that make a clean install. I definitely think it’s better than installing nothing so you should buy it and try it. If you want the factory connectors you could order them from Ford and probably still be way under budget! Post pics and results when you are done.Not to be a dick guys, but I'm trying to find out more thoughts on the cheaper alternatives. I don't want to see my post get derailed too bad... Thanks for understanding.
Awesome reply. I appreciate it! I was thinking about making up a cpl hoses like you said too. I'll post up what I end up doing.My thought on the $50 can that you show is this.... it looks like it has the same ball valve that’s used on my RXP Can, which is a quality valve, and the rest of the cans parts look to be ok also as far as quality goes. What the kit is lacking is the factory ford hose connectors that make a clean install. I definitely think it’s better than installing nothing so you should buy it and try it. If you want the factory connectors you could order them from Ford and probably still be way under budget! Post pics and results when you are done.
Not much the dealerships can bother you for. They can try to deny your claim, but unless they can prove that your issues are a result of the can there's nothing they can do legally.Maybe a silly thought, but what do the dealerships think of these? Just wondering as far as warranty issue's? I honestly don't understand why they aren't factory installed.
Sent from my SAMSUNG-SM-G870A using Tapatalk
