Ceiling A/C Vent Keeps Shutting - Third Row
BSarchet
Little Flock, AR
I couldn't find this anywhere, but I was wondering if anyone knows of a trick to keep the third row AC vent open? My daughter's vent blows closed any time the fan is above about the 4 setting. The louvers are loose and catch the air and blow closed. Obviously that's the opposite of what you want on a hot day.
Anyone deal with this and know of some trick? I was thinking a little bit of electrical tape or something, I have no idea. Any help appreciated.
kbrocaille
St. Louis, MO
I have the same issue in my 2021. I had the dealership take a look at it. They have ordered a new set of covers. We compared the 2021 to the 2023 and the newer models seem to be tighter so they don't have the issue. I'm still waiting for a call back from the dealership to have the new ones installed. I'll let you know if this fixes the issue.
AJ82
I haven't noticed that on ours, they seem to be pretty tight, at least right now. You could put a small piece of foam/sponge material in between the louvers to prevent them from turning. Wouldn't damage anything I can think of. I haven't tried it to confirm it would do the trick but I think it would.
JAMADOR
Spring, TX
Luckily we haven't had this issue in or Exped nor my Explorer.
Out Flex on the ot her hand, could blow all 4 shot with the rears on high. Annoying on a hot day, and quite noisy when they're shut.
bigboi66
Florida
2020 max here and have the same issue. They are definitely loose and just flop all around when driving and hitting any bumps. Anyone have a solution or know of replacing the vents will fix this for a non returning issue?
BSarchet
BSarchet
Little Flock, AR
Vents are extremely easy to replace. They just twist and come out like an IKEA cam lock. They are less than $20 online. Dealer price was $50. I got mine covered by warranty.
Mr Big
Tampa Bay, Florida USA
If all else fails you could always use a tiny bit of silicone caulk, spread it on the joints with a toothpick or small applicator. That's how I fixed my Excursion vents flopping around.
Retiredusps
N.J.
You might try a spring clip and push it up to the side (spring clip for keeping papers togeather )
