change the spark plugs or no??
Buttz
wisconsin
i have 106k on my 08, it runs great. I was thinking about changing the plugs Im just dreading one breaking off.... what is everyone else doing in this area? running them till there's a issue or changing them b4 that happens? thanks!
ManUpOrShutUp
PA
Change them before there's an issue. Bad plugs are the most common cause of dead coils. One coil costs as much as a set of 8 plugs.
Do you know the build date of your Expedition? If built on or after 10/9/07 you have a one-piece plug.
Habbibie
Is it Christmas yet?
Chicago
Wouldn't hurt to have the extractor tool by you while doing it, or a second source of transportation in case one does break and no tools to remove it
cootersEL
Ann Arbor, MI
All 8
I waited until nearly 117K and broke all 8. I suppose each plug that breaks is a greater risk, so I wouldn't push it. Especially if you're not keeping the truck past the next plug change.
I'll also add that I was dreading it, looking for the best method (followed the TSB, but also used a light impact, and switched it to PB Blaster on the other side - none of this mattered), and actually using the tool was so easy I wish I hadn't wasted so much time trying to figure out the best method to get them out without breaking them.
Be sure when they break, they break off flush, and I wouldn't push the ceramic as far as recommended. I lost a strap in one cylinder and a piece of ceramic in the other, but whenever I left about 1/16" from bottoming the pusher I only broke one side of the ground strap and didn't lose any pieces. Pieces aren't good.
Regards,
carlos08
Fl
Replace them before there's a problem. Besides plugs are not too expensive.
bshore3rd
PA/MI
I sprayed Sea Foam Creep around each plug and waited 2 weeks before I changed the plugs. Each one came out without a problem. Perhaps worth a try
limitedex
Ok
Yes just do it. In fact you're beyond what most Ex owners consider "late" worrying about hem breaking.
They're like $8/each. What's the issue?
Habbibie
Chicago
Bro one motorcraft SP-515 plug is the same price as 6 platinum NGK's for my wife's car, **** never seen more expensive spark plugs in my life.
ManUpOrShutUp
PA
They're ~$9 each at both Amazon and Rock Auto. That's a bit pricey for what they are, but they're not even close to the most expensive plug out there. Regardless, the SP-509 is the recommended plug for an '08 Expedition and those are ~$8 each.
TORNIT07
WNC
When I replaced mine at around 105,000 miles I began to add SEAFOAM & GUMOUT internal engine/injector cleaners every time I filled up. About once a week. The idea is that the cleaners SHOULD help by breaking up & softening hard carbon deposits on the plugs. I feel it really can't hurt and I changed the oil right after the plugs anyway.
Of eight only three broke. I had purchased the extractor tool from NAPA before hand for something like $70.00
It wasn't terribly bad. Removed all the coils and other stuff in the way one day & did the plugs the next & put everything back together. If I didn't have the health issues I do it would have taken me a lot less time...maybe three hours or so.
