check advance trac
tonydiv
technical advisor
Middle River, MD
That system uses inputs from steering, brakes, throttle, a yaw sensor, a g sensor and the abs sensors. There's a lot to go wrong. Without getting codes, it's going to be hard to figure out. (unless you get lucky with the fuses)
kawi_200
Everett, WA
I'm having the same issue on my 05 EB. What is the best way to go about getting codes? My friend has an OBD2 scanner if that will work.
dcorday
Same problem. I am trying to find the vdm module to test it. Seems the vdm module is the advancetrac from what I have been told by dealer
