StephanSloan
All-
I have a 2008 Expedition EL Limited with 185,--- miles. Yesterday the info system read "Check Brake System" with the Brake and ABS lights on and the stability control light (sliding car symbol) also displayed to the right of the Check Brake System readout.
I have a ScanGauge II that I checked to see if there were any codes but found none. The lights reset every shut down and reappear when the vehicle reaches about 10 miles an hour.
I found threads with a TSB on the stability control and on replacing the ABS module but am surprised there are no codes.
Is my ScanGauge missing the codes or is there a better way to diagnose?
Thank you,
Stephan
Thank you,
Stephan
