Chrome Window Sill Strip
Keydo
SoCAL
Chrome Window Sill
Just finished replacing the door window trim with the equivalent chrome ones from the '03 Navigator. Looks very sharp!
All trim pieces are easy to swap out except for the driver's door.
For the passenger front door, simply pull up on the rear portion of the trim and slide out.
For the rear passenger door, pull up on the front portion of the trim and pull down on the rear portion.
The driver side window sill trim is difficult to change out because of the keypad which has a wire connector which needs to be disconnected.
In order to do this, the interior door panel needs to be removed.
Rather than getting into it, here is a good link on removing the interior door trim panel.
http://www.expeditionforum.com/forums/showthread.php?s=&threadid=207&highlight=door+panel+removal
The door mirror needs to be removed. There you'll find the wire connector to the keypad. Once it's disconnected, then it's a little easier to remove the trim.
Once out, the new trim pops in.
One of these days, I'll get some pictures out.
G
Guest
Where did you get the chrome stripping
Hi Keydo,
Thanks for the information! I just purchased a black 2003 XLT and I would like to place as much chrome as possible on it (my taste I guess). Quick question, where did you purchase the chrome strips you are mentioning? I quickly glanced over your post so I hope I didnt miss it somewhere. Thanks in advanced.
K
Keydo
SoCAL
Just got a new camera, so I'm hoping to get some pictures up. Still need a place to host them though.
As for the moldings, I got them from a reseller on ebay. Here is his email address.
[email protected]
He works for a rather large dealership and orders a lot of stuff, so can usually sell stuff cheaper than the list price.
G
Guest
Thanks for the information! I will look it up and post some pictures as well once they are on. Thanks again!
