Climate control auto mode
verna2197
Tn
When I put my system in auto mode the heat only comes out on the floor. When in auto I thought that it would come out on floor and thru dash, anyone else have this. I have a 2017
Plati
You did look in the Owners Manual, right?
No offense … sometimes people forget this step.
I know on my 2014 I can adjust where the air blows out.
JohnT
Canada
Both GM and Ford auto climate controls seem to like to default to a trickle of hot air from the floor once the interior has reached the appropriate temp
I assume its working on the theory that heat rises so a constant trickle of hot air will permeate the cabin.
What I find is I end up with a burning right foot.
Typically I resort to overriding the auto by either manually selecting all 3 vent types and letting the auto system figure out the air temperature and fan speed or alternatively setting a medium fan speed and letting the auto figure out where to send it and how hot. But on damp days it's not clever enough to realize the window is fogging so I typically go with option 1
gixer2000
Retrofit or Bust
Massachusetts
I use the auto mode and it is supposed to blow on the floor. Fords way of trying to make the space overall more comfortable and not have it blowing directly on the occupants.
TobyU
Ohio
Auto....the most evil...non user friendly hvac control ever forced on us!!
I hate it.
Caddys and Lincolns have to have it. High end Buicks too.
I hate the having a car with it esp Cadillac as you have so little control over where the air goes.
I never push the auto button on Ford unless I'm doing a self test.
Also due to blend door and actuator issues.....IF they had a know and you rarely moved them...It should last longer. BUT with fords temp...EVEN not on auto, It will move the blend door after car warms up.
I HATE HATE HATE that.
I want my blend door to be where I put it and stay.
I may want full heat and turn blower down when warm enough or I may leave at 3/4-7/8 hot and never move it.
SHOULD BE MY decision.
The GMs that put air to def when you turn temp up when car is cold DRIVES ME NUTS.
ManUpOrShutUp
PA
OP, as others have said, auto sends the heat to the floor.
Anyone notice if Auto will also turn on / adjust the rear climate controls?
In my truck f you want auto heat/AC in front and rear you just hit the rear button, which will turn on front and back if neither is on.
verna2197
verna2197
Tn
Ok but will it still be in auto mode if I hit the rear button?
gixer2000
Retrofit or Bust
Massachusetts
I just pulled this from the service manual. hope it helps
Electronic Automatic Temperature Control System
The electronic automatic temperature control (EATC) system operation is determined by the settings on the EATC module. The EATC system automatically maintains a selected temperature for vehicle interior comfort. The EATC system is composed of the EATC module, blower motor speed control, mode door actuator, air inlet door actuator, temperature blend door actuator, in-vehicle temperature sensor and solar radiation sensor to control the various functions.
When the EATC module is set to AUTO:
  • the air distribution direction, blower motor speed and A/C compressor operation are automatically controlled based on the temperature(s) selected.
The EATC module manual override settings:
  • allow the air distribution direction to be manually selected.
  • allow the blower motor speed to be manually selected.
  • allow RECIRCULATION mode to be manually selected in all modes except DEFROST. The A/C request can be cancelled by pressing the A/C request switch, turning the indicator OFF.
  • allow A/C compressor operation to be manually selected except in DEFROST.
The auxiliary climate controls:
  • select the auxiliary blower motor speed.
  • select the auxiliary airflow mode/temperature.
The EATC module also includes:
Auxiliary Climate Control System
An auxiliary climate control system is available as optional equipment. The auxiliary climate control system operation is determined by the settings on the front or rear auxiliary climate control assembly. The auxiliary climate control assemblies include a blower motor switch and temperature control/air distribution mode knob, neither of which can be individually serviced.
Auxiliary blower motor operation is enabled when the EMTC or EATC is in any mode except OFF. The auxiliary system air can be cooled below interior air temperature only when A/C compressor operation has been requested by the settings of the climate control assembly of the base (front) system. The auxiliary system air can be heated at any time.
The front auxiliary climate controls:
  • are built into the dual-zone EMTC or EATC module. The blower motor speed can be set to OFF, LO, MED LO, MED HI or HI by pressing the auxiliary blower FAN button either right (higher) or left (lower). The temperature/airflow mode can be adjusted by pressing the rear button either right (warm/floor) or left (cool/panel). If the front (main) driver side temperature is set to full COOL or full HEAT, the auxiliary temperature will be set to the same as the driver and cannot be changed. When the front auxiliary REAR button is depressed, all control of the auxiliary climate control system functions are then transferred to the rear auxiliary climate control assembly and the auxiliary temperature can be fully independently controlled.
The rear auxiliary climate control assembly:
  • blower motor switch controls the auxiliary blower motor speed only when the front auxiliary climate control assembly blower motor switch is set to REAR. The blower motor speed can be set to OFF, LO, MED LO, MED HI or HI.
  • temperature/airflow mode control switch is a potentiometer that outputs a variable voltage to the auxiliary temperature blend door actuator and auxiliary mode door actuator to set the position of the auxiliary temperature blend and mode doors only when the front auxiliary climate control assembly blower motor switch is set to REAR. When A/C compressor operation has not been initiated (A/C compressor commanded on) by the EMTC or EATC module (as equipped), the auxiliary climate control system cannot cool the air below that of the interior air temperature.
Drmayer88
Wi
I sometimes think I’m the only person that uses auto mode religiously. I rarely find myself overriding it to be comfortable.
Every other persons car I get into that has an auto mode doesn’t use it. It’s always way too hot/cold and they are always messing with or.
Just an observation I thought I’d share [emoji6]
gixer2000
Retrofit or Bust
Massachusetts
I love auto mode but every time my wife drives the car i get in to the fan be cranked up on high. Really grinds my gears considering auto works so well
Sgt Darkness
East Tennessee
Set the desired temp then hit auto button on dash or on sync screen. This is supposed to start auto mode, however, on my Silverado in auto mode the a/c light on the a/c button comes on to show the a/c is on. In the Expy when you hit the auto button the light on the a/c button does not come on......so I hit the a/c button to ensure it’s on?? Or, is it on when I hit the auto button or am I missing something?
gixer2000
Retrofit or Bust
Massachusetts
In auto if the cabin temp is warmer then setpoint it should start the AC. It may take a minute and needs to be above 43°. Below 43° the AC light won't come on but will allow in outside air to cool the cabin.
TobyU
Ohio
The manual should say " In auto mode position the system does all kinds of crazy things, changes fan speed and directs air places you don't t want it to go and runs the compressor almost continuously.
I don't think I've ever seen an auto one that ever turned comp off.
Sgt Darkness
East Tennessee
Thanks for explaining that to me. I try to run the a/c in Winter on occasion to keep the oil in the Freon circulating so it will lube the o-rings.
TobyU
Ohio
Always a good idea but I have to use defrost so often that that takes car of it.
I can't stand driving around in auto with ac running wasting fuel and life of compressor and clutch.
Plati
I always use AUTO mode. Only "complaint" I have is … when sun comes out and it warms up - vehicle will heat up and I have to turn temp down. Or when sun goes down (or under clouds) vehicle cools inside and I have to turn heat up. Seems like it ought to adjust for that? I often run the REAR a little hotter or cooler depending on conditions. Cant really splain why. In extreme weather I have to have rear adjusted for temp or it overpowers front.
