FOGLER
I had my timberline for six months and I do enjoy it however, I'm thinking to lift the front and rear using coilovers if anybody has installed them from fox or king I would really appreciate the advice.
So I have tried to get the kings but what if I do install them front and rear without the RC.Regardless of the coil over you get I would consider some parts from the rough country lift.
The rear link bars to keep the rear centered (IMO this looks bad when not) and a new lower front control arm to maintain correct ball joint angle.
If I were every to do mine I would go with some RC parts then the King shocks. Fox does not have any direct bolt on right now as far as I know.
The only issue with the rear would be cosmetic. As you lift the rear the rear wheel swings forward and it will not be centered when looking from the side. For the fronts its debatable but there is a point where the ball joints will run at a weird angle.So I have tried to get the kings but what if I do install them front and rear without the RC.
