Front transfer case oil. Ford!WTF!!! Which is it?!
https://torqueking.com/ford-full-size-4x4-transfer-case-fluids/
Either one. But you’ll probably not find XL-12. LV is the replacement.
The LV bottle says “not for transfer case use”
Ok…so I’m also confused. I did my rear diff today. I was going to do the transfer case. The manual calls for ‘Motorcraft Mercon ATF’. I went to auto parts store…and they claimed Mercon LV was what I needed. I’m not going to use it unless I know 100% it’s correct.Just don’t touch LV if you have a 2007 or 2008. You can only use Mercon SP in the transmission and then Mercon V for transfer case. SP is a special fluid you can only get from Ford too.
So for 2008 Expedition, don't use Mercon LV? What's the reason? Which do you recommend?Just don’t touch LV if you have a 2007 or 2008. You can only use Mercon SP in the transmission and Mercon in tcase. SP is a special fluid you can only get from Ford too.
