Constant whirring sound in the engine compartment 2000 Exp.
HighSierra49er
HighSierra49er
Roseville, Ca.
I received my re-built ABS Module yesterday and installed it today. One day turnaround from Rapid Electronics, located just outside of Austin, Texas. Everything went back together a lot quicker than it came apart, and the brake system is back to working as it should. I took the truck a few minutes ago to a local repair shop to have the OBD scanned, and no issues found. A much less costly repair than I was expecting, and learned a bit more about the truck during the process. So much quieter without the pump motor running.
Glad you got everything up and behaving right! Thanks for the new post, it will help other members with same issue.
