coolant cap question................
red423
Miami
Ok so I am losing coolant, I go to autozone and borrow the pressure tester and do 10 lbs for 5 minutes and she holds, I have front and rear heat. Buuuutttt my coolant cap since I got the truck you put it on and it would click like the gas cap. I pressure test it and it won't hold even 5 lbs of pressure, I buy a new one from standt, now question is the new cap screws on tight like a cap. No clicks. Did the original caps click?? Where is a heating system diagram for an EB showing all hoses, valves and connect points so I can verify a few things????
I am still checking it today for leaks, but since the system is so big it is a little difficult.
That cap, if it was bad, will the coolant evaporate out of the tank???
Thanks red423
Bedrck47
Elizebethtown, PA
Radiator Cap Pressure Test Specifications
Pressure relief opening pressure 110 kPa (16 psi)
Test your system at 16psi
