COP (coil) mystery?
Texas Dave
Fairfield, TX
In the past year I have had to replace the coil on cylinder 7 of my 5.4L 2007 Expedition three times. It begins with a stumble when accelerating which sets off a misfire on cylinder 7 code. I replace the coil and the engine runs great for a few months. I have also replaced the wiring connector. Any idea why just this one coil keeps going bad?
1955moose
You've either got a small coolant leak near that coil, that's getting it wet, and shorting it out. Or the second scenario could be your replacing with cheap coils that don't last. Also be sure to replace that boot on #7 coil, if you haven't already. Do you have any known good take off coils you can try? Be sure to swap in a new sparkplug for #7, a Ford one is preferred.
Texas Dave
Texas Dave
Fairfield, TX
When this first happened I replaced all of the coils with moderately priced replacements...not the cheapest, but not the most expensive. When the #7 coil failed again I replaced it with one of the original coils I had removed. I tend to think you may be right about the plug. Can a bad plug cause a coil to go bad?
bryandreilly
