marine_hm
Problem: My 99 Expedition "courtesy lights" go on and off all day & night. To keep from killing the battery, I pulled fuse number 14? if not mistaken under the dash. Other part of that problem; There are little black boxes I'm assuming are relays, when I pull the fuse or put it back in one of those boxes have an audible click. I tried to pinpoint which one by placing a finger on each one. One at a time and do the same thing with the fuse to determine which one is clicking. I still can't tell which one is doing it. The small rectangle one on the top left is falling apart. Would one of these be the culprit of the courtesy lights going on and off. I have lubricated all the door latches. Opened and slammed them many times. Cannot reproduce the issue by doing that. They do come on when I open the doors. Each one chimes when the door is opened. It's just that when all the doors are closed, the courtesy lights go on and off all by themselves, mostly staying on for long periods. Your help is much appreciated. I have googled it and it seems to be a common problem, so far I have not seen a real solution.
Thanks. Nick
Thanks. Nick
