Crank sensor broken in engine block
Perry7221
Mahopac ny
Okay so I got a new sensor to replace the old and when I went to change it it was broken off in the block. Any ideas on easiest ways to get it out??
stamp11127
Temple, Georgia
Use a small pic to keep it from spinning while drilling a hole in the center. Run a course drywall screw deep into the hole. Gently pull sensor out on first attempt.
1955moose
Same technique for removing frozen d cell battery in a mag/kel light, except you use a bigger lag bolt screwed through a 2x4 or equivalent.
