Crate Engines
djljr
Will any of the crate engines available from FRPP drop into an Expy without modification and direct interface with the Expy engine management system?
NASCAR Mike
Syracuse NY
You could use a short block and install your heads, intake and other electronics.
Only thing you need to check is valve clearances if the compression is higher than your stock engine.
green03
College Station, TX
what year model is yours? 03 and newer have a different short block with a thicker block and different oil filter location...
