Damaged Pass rear axle pushed forward 4" repair
GlennSullivan
Yorktown NY & Jupiter FL
Might be a good time to replace both rear shocks if they were not done in last 30-40K. In any case I would not reuse the shock on the damaged side, rod prolly bent, but would either make sure existing and doner springs match or reuse your old spring. Why didn't you take the bumper cover and all bracketry for same as well?
S
scholzee
Buffalo NY
Got the bent parts off not sure what new parts I may want to buy like upper tie rod and maybe cam adjust washers to go with the parts I got from u pull it yard.Bent.jpgBent2.jpg
Retiredusps
N.J.
Boy you have more guts than me working on a truck balanced on rims!!!!!!!!!!!!!! Oh by the way how did you bend up everything ?? you really nailed something !!!
S
scholzee
Buffalo NY
The rear frame is supported on jack stands and front wheels on ground, I shook it and no movement. really no body parts under the truck more out side body working in wheel well. Working on vehicles for 40 plus years and agree with you on safety. Hot days my jack stands will sink some in asphalt drive that's why 1/2" plywood under them. Wife is a great driver just lost parking lot awareness and back into cement block for lamp post.
S
scholzee
Buffalo NY
That is one valuable stack of parts!
Between anti-seize and thread lock I seem to put something on everything I assemble, but for this I'd just assemble everything and coat the assembled stuff with Fluid Film or something like that to prevent future rust. Put some bearing grease on the outer axle splines to make future disassembly easier.
That pile of parts cost me $116.00 as I removed them myself and $2.00 fee to enter junk yard the put that fee towards their insurance. Can bring any tool but torch / flame or grinders / spark. Battery power impacts Sawzall drill all good.
mjp2
Howell, NJ
You saved yourself literally thousands. Don't lose that yard's number.
S
scholzee
Buffalo NY
Junkyard located Buffalo New York you pull parts off yourself
Part NamePriceCore Price
A/C COMPRESSOR$23.90$5
A/C CONDENSER$21.14$5
A/C DRYER$11.95$2
A/C EVAPORATOR$13.78$2
A/C LINE DOUBLE$20.23$2
A/C LINE SINGLE$11.95$2
ABS UNIT$23.90$5
ABS UNIT W/ MASTER CYL$34.01$5
ACTUATOR 4X4$30.34$5
AIR CLEANER HOUSING$11.02$2
AIR CLEANER LID$5.51$0
AIR FILTER$0.91$0
AIR FLOW SENSOR$21.14$3
AIR INTAKE COLD$14.71$2
AIR PUMP VALVE$6.44$0
AIR SNORKEL$7.35$0
ALTERNATOR$21.14$5
ANTIFREEZE$2.75$1
ARM REST$5.51$0
ASHTRAY$5.51$0
AXLE ASSEMBLY FRONT$84.59$20
AXLE ASSEMBLY REAR$84.59$20
AXLE BEAM TRAILING$52.41$10
AXLE SHAFT FWD CV AX$23.90$5
AXLE SHAFT RWD$20.23$2
BACK GLASS$18.38$0
BACKING PLATE$8.27$2
BACKING PLATE W/ ACCESSORIES$14.71$2
BALL JOINT$6.44$2
BATTERY BOX$6.44$0
BATTERY CABLE$8.27$0
BATTERY USED$32.18$10
BELT TENSIONER$10.11$2
BENCH SEAT$22.07$2
BENCH SEAT HALF$16.55$2
BENCH SEAT W/ BELTS$32.18$2
BRACKET$6.44$2
BRAKE CABLE$9.19$0
BRAKE CALIPER$13.78$2
BRAKE CALIPER BRACKET$5.51$0
BRAKE DRUM (NO HUB)$12.87$2
BRAKE DRUM W/ HUB$19.31$2
BRAKE FLUID RESERVOIR$6.44$0
BRAKE HOSE / LINE$5.51$0
BRAKE LEVER (PARKING)$9.19$2
BRAKE MASTER CYLINDER$15.63$2
BRAKE PAD OR SHOE$2.75$0
BRAKE PROPORTIONING$12.87$2
BRAKE PWR/HYDRO BSTR$18.38$2
BRAKE ROTOR (NO HUB)$11.95$2
BRAKE ROTOR W/HUB$17.47$2
BUCKET SEAT$21.14$2
BUCKET SEAT W/ POWER$28.50$2
BUG DEFLECTOR$11.95$0
BUMPER BRACKET$9.19$2
BUMPER COVER FRONT$41.37$4
BUMPER COVER REAR$41.37$4
BUMPER END CAP$8.27$0
BUMPER FILLER$8.27$2
BUMPER FOAM/SHOCK$5.51$2
BUMPER METAL FRONT$36.78$4
BUMPER METAL REAR$36.78$4
BUMPER PUSH GUARD LG$32.18$5
BUMPER PUSH GUARD SM$16.55$3
BUMPER REINFORCEMENT FRONT$14.71$2
BUMPER REINFORCEMENT REAR$14.71$2
BUMPER VALANCE$11.95$0
CAM SHAFT$18.38$2
CARBURETOR$21.14$5
CARGO NET$5.51$0
CARPET PER SECTION$9.19$0
CENTER CAP$2.75$0
CHARCOAL CANISTER$11.95$0
CLOCK SPRING$8.27$0
CLUTCH CABLE$8.27$0
CLUTCH DISC$13.78$2
CLUTCH FORK$13.78$2
CLUTCH HOUSING$25.74$3
CLUTCH MASTER CYLINDER$17.47$2
CLUTCH PRESSURE PLATE$16.55$5
CLUTCH SLAVE CYLINDER$16.55$2
CLUTCH THROWOUT BEARING$5.51$2
COIL IGNITION$7.35$2
COIL PACK$22.98$3
COMPUTER BCM$12.87$1
COMPUTER ECM$22.98$2
CONNECTOR MISC.$3.67$0
CONSOLE (LARGE)$16.55$3
CONSOLE (SMALL)$12.87$2
CONSOLE COVER (LARGE)$11.95$0
CONSOLE COVER (SMALL)$7.35$0
CONTROL ARM$20.23$2
CONVERT FRAME WITH SKIN$73.56$6
CONVERTIBLE FRAME$41.37$4
CONVERTIBLE LIFT PUMP$18.38$3
CONVERTIBLE SKIN$41.37$0
COWL WIPER GRILLE$12.87$3
CRUISE BRAIN$15.63$2
CRUISE CONTROL LEVER$9.19$0
CUP HOLDER$6.44$0
CUP HOLDER LINER$2.75$0
CUT (LARGE)$82.76$15
CUT (MEDIUM)$59.77$10
CUT (SMALL)$27.58$5
CUT (X-LARGE)$114.94$25
CYLINDER HEAD OVERHEAD NO CAM$51.49$5
CYLINDER HEAD V6 V8$30.34$6
CYLINDER HEAD W/ DOHC$69.88$8
CYLINDER HEAD W/ SOHC$57.01$6
DASH ASSEMBLY (BARE)$24.83$4
DASH PAD$10.11$2
DECK / TRUNK LID NO GLASS$34.01$3
DECK LID WITH GLASS$41.37$5
DIFFERENTIAL INDEPENDENT SUSPENSION$45.97$10
DIPSTICK/TUBE$3.67$0
DISTRIBUTOR$25.74$5
DISTRIBUTOR CAP$6.44$0
DOME LIGHT$4.59$0
DONUT SPARE$9.19$0
DOOR$41.37$5
DOOR GLASS$18.38$0
DOOR HANDLE$5.51$0
DOOR HINGE$5.51$2
DOOR LATCH$7.35$2
DOOR LOCK ACTUATOR$8.27$0
DOOR PANEL$10.11$0
DOOR RUBBER$4.59$0
DOOR STRIKER$2.75$0
DOOR WIND DEFLECTOR$3.67$0
DRIVE SHAFT FRONT$30.34$6
DRIVE SHAFT REAR$16.55$2
EGR VALVE$7.35$2
EMBLEMS (ANY)$2.75$0
ENGINE (NO STR,ALT,P/S,A/C,TC,SC)$197.70$35
ENGINE BLOCK$91.95$25
ENGINE COVER$11.95$2
ENGINE CRADLE$39.54$3
ENGINE CROSSMEMBER$16.55$3
ENTRANCE FEE$2.00$0
EXHAUST MANIFOLD$17.47$2
EXHAUST MUFFLER$11.02$2
EXHAUST PIPE$9.19$2
EXHAUST PIPE FLEX$14.71$2
EXHAUST PIPE Y$12.87$2
EXHAUST RESONATOR$4.59$2
FACE PLATE$8.27$0
FAN BELT SERPENTINE$5.51$0
FAN BELT V$2.75$0
FAN BLADE$10.11$2
FAN CLUTCH NO BLADE$13.78$2
FAN CLUTCH W/ BLADE$18.38$2
FAN ELECTRIC RADIATOR$18.38$3
FENDER$33.10$3
FENDER FLARE / EXT$9.19$0
FENDER INNER PLASTIC$6.44$2
FENDER INNER STEEL$9.19$2
FENDER SKIRT REAR$8.27$2
FLOOR MAT EACH$2.75$0
FLYWHEEL AUTOMATIC$18.38$3
FLYWHEEL STANDARD$27.58$3
FOG LIGHT$8.27$0
FUEL FILLER DOOR$7.35$0
FUEL FILLER NECK$12.87$0
FUEL FILTER$2.75$0
FUEL INJECTION PUMP DIESEL$51.49$5
FUEL INJECTION RAIL$9.19$2
FUEL INJECTION SYS$41.37$10
FUEL INJECTOR (EACH)$9.19$2
FUEL LINE EACH$5.51$0
FUEL PUMP$18.38$3
FUEL PUMP W/ SEND$25.74$3
FUEL SEND UNIT$10.11$0
FUSE$0.09$0
FUSE BOX COMPLETE$14.71$0
GAS CAP$5.51$0
GAUGE$9.19$0
GLASS REAR WINDSHIELD$18.38$0
GLASS T-TOP$18.38$0
GLOVE BOX$6.44$0
GLOVE BOX DOOR$5.51$0
GLOVE BOX LOCK$2.75$0
GRILLE LARGE$22.07$2
GRILLE SMALL$13.78$2
HARMONIC BALANCER$13.78$2
HEADER PANEL BARE$26.67$4
HEADLAMP COMP BULB$2.75$0
HEADLIGHT BEZEL DOOR$8.27$0
HEADLIGHT BUCKET$4.59$0
HEADLIGHT COMPOSITE$24.83$2
HEADLIGHT MOTOR$18.38$3
HEADLIGHT SEALED BEAM$7.35$0
HEADLINER$13.78$0
HEAT RISER$5.51$0
HEATER ASSEMBLY$36.78$3
HEATER BLOWER MOTOR$18.38$3
HEATER CONTROL VALVE$5.51$0
HEATER CONTROL W/ AC$20.23$2
HEATER CONTROL W/O AC$10.11$2
HEATER CORE$18.38$3
HEATER HOUSING BARE$18.38$3
HEATER RESISTOR$11.95$0
HOOD$45.06$3
HOOD HINGE$5.51$2
HOOD LATCH$5.51$0
HOOD RELEASE CABLE$10.11$0
HOOD SHOCK / PROP$5.51$1
HORN$3.67$1
HOSE MISC.$2.75$0
HUB 4X4$24.34$3
HUBCAP WHEEL COVER$2.70$0
IDLER ARM$9.91$2
IGNITION SWITCH$10.81$2
INSTRUMENT CLUSTER$23.43$3
INTAKE MANIFOLD$19.83$3
JACK$4.50$0
JUMPER CABLES$4.50$0
K – FRAME$37.86$3
KEY FOB$4.50$0
LICENSE PLATE FRAME$2.70$0
LIGHT SOCKET$1.80$0
LIGHTER / LIGHTER SOCKET$1.80$0
LUG NUT$0.09$0
LUG WRENCH – 4 WAY$4.50$0
LUG WRENCH TIRE IRON$2.70$0
LUGGAGE RACK$18.03$2
MARKER LIGHT$8.11$0
MEDIA/DVD CENTER$32.45$3
MIRROR REAR VIEW$6.31$2
MIRROR SIDE VIEW$11.72$2
MOLDING LARGE$9.91$0
MOLDING MEDIUM$6.31$0
MOLDING SMALL$3.60$0
MOLDING X-LARGE$13.52$0
MOTOR MOUNT$9.01$2
MUD FLAP EACH$1.80$0
OIL CAP$2.70$0
OIL COOLER$9.91$2
OIL PAN ALUMINUM$26.14$3
OIL PAN STEEL$21.63$2
OIL PUMP$12.62$2
OWNERS MANUAL$4.50$0
OXYGEN SENSOR$9.91$2
PARCEL REAR INTERIOR$10.81$0
PARKING LIGHT$8.11$0
PEDAL (EACH)$9.91$0
POWER STEERING MOTOR$37.86$3
POWER STEERING PUMP$18.03$5
PULLEY$5.40$1
QUARTER GLASS$18.03$0
QUARTER PANEL PLASTIC$43.27$2
RADIATOR$37.86$6
RADIATOR OVERFLOW TANK$8.11$0
RADIATOR SHROUD$9.91$2
RADIATOR SUPPORT$36.06$3
RADIO$18.93$2
RADIO AMPLIFIER$13.52$2
RADIO ANTENNA MAST$4.50$0
RADIO ANTENNA POWER$12.62$2
RADIO ANTENNA STANDARD$6.31$0
RADIO CD DISC CHANGER$14.42$2
RELAY$1.80$0
RING AND PINION$82.93$20
ROCKER ARM$3.60$0
RUNNING BOARD (EACH)$19.83$2
SEAT BELT$11.72$2
SEAT BELT BUCKLE$5.40$2
SEAT COVER (EACH)$2.70$0
SEAT HEADREST$7.21$0
SEAT MOTOR$18.03$3
SEAT TRACK$9.01$2
SENSOR MISC.$7.21$0
SHIFT ARM LEVER$7.21$2
SHIFT CABLE$9.91$0
SHIFTER ASSEMBLY$19.83$2
SHIFTER BOOT$2.70$0
SHIFTER KNOB$2.70$0
SHOCK ABSORBER AIR$9.91$2
SHOCK ABSORBER STD$3.60$2
SMOG PUMP$18.03$2
SNOW BRUSH$1.80$0
SNOW PLOW BLADE$68.96$0
SNOW PLOW MOUNT$68.96$0
SNOW PLOW PUMP$68.96$0
SOLENOID (NON TRANS)$8.11$0
SPARE TIRE CARRIER$13.52$2
SPARK PLUG/WIRE$0.90$0
SPEAKER$4.50$0
SPEAKER BOX$11.72$0
SPEAKER GRILLE$2.70$0
SPEAKER W/ AMP$11.72$0
SPEEDOMETER GEAR$9.91$0
SPINDLE$21.63$2
SPINDLE W/ BEARING$31.55$3
SPOILER$18.03$2
SPRING COIL$8.11$2
SPRING LEAF$18.93$3
STABILIZER BAR$18.03$2
STARTER$20.73$7
STEERING COLUMN NO AIR BAG$27.94$3
STEERING CONTROL VALVE$15.32$3
STEERING GEAR ANY$26.14$3
STEERING HOSE POWER$7.21$0
STEERING LINKAGE$10.81$2
STEERING RACK & PINION$32.45$6
STEERING SHAFT$12.62$0
STEERING WHEEL$10.81$2
STEERING WHEEL COVER$3.60$0
SUN VISOR$6.31$0
SUNROOF ASSEMBLY$40.56$0
SUSPENSION AIR PUMP$27.94$3
SUSPENSION AIR SPRING$37.86$3
SUSPENSION STRUT$18.93$3
SWITCH MISC.$8.11$0
TAIL LIGHT$21.63$0
TAIL LIGHT – FINISH$34.25$0
TAIL LIGHT CIRCUIT$9.91$0
TAILGATE TRUCK$41.46$3
TEE SHIRT$10.00$0
THERMOSTAT$0.90$0
THERMOSTAT HOUSING$6.31$2
THROTTLE BODY$20.73$6
THROTTLE CABLE$8.11$0
TIE ROD ASSEMBLY$14.42$3
TIE ROD END (EACH)$6.31$2
TIMING CHAIN$9.91$2
TIMING CHAIN COVER$14.42$2
TIMING GEAR$10.81$2
TIRE AND ALUMINUM WHEEL$27.58$14
TIRE AND STEEL WHEEL$21.14$2
TIRE ONLY$21.14$0
TOOLBOX METAL$45.07$0
TOOLBOX PLASTIC$27.04$0
TORQUE CONVERTER$17.12$4
TORSION BAR$18.03$2
TRAILER BALL$1.80$0
TRAILER BALL INSERT$6.31$0
TRAILER HITCH BUMPER$12.62$2
TRAILER HITCH RECEIVER$27.94$2
TRAILING ARM$18.03$2
TRANS CROSSMEMBER$14.42$2
TRANS SHIFT SOLENOID$36.06$6
TRANSFER CASE$72.12$24
TRANSMISSION$108.51$24
TRANSMISSION MOUNT$9.01$2
TRANSMISSION OIL LINE$4.50$0
TRANSMISSION OIL PAN$18.93$3
TRANSMISSION VALVE BODY$54.09$14
TRIM RING$3.60$0
TRUCK BED LINER$45.07$0
TRUCK BOX SIDE$45.07$10
TRUCK BOX W/OUT GATE$117.19$25
TRUCK CAP$50.48$6
TRUCK CAP DOOR$11.72$2
TRUNK CARPET – LINER$7.21$0
TRUNK SHOCK / STRUT$4.50$1
TURBO / SUPER CHARGER$50.48$14
TURBO INTERCOOLER$33.35$3
TURN SIGNAL SWITCH$18.03$2
TURN SIGNAL W/ ACCESSORIES$21.63$2
VALVE COVER$9.91$3
VENT (INTERIOR)$1.80$0
VENT GLASS$18.03$0
VOLTAGE REGULATOR$7.21$2
WASHER BOTTLE$7.21$1
WASHER FLUID$1.35$1
WASHER JET$2.70$0
WASHER PUMP$8.11$1
WATER PUMP$9.91$2
WHEEL BEARING$9.91$2
WHEEL BEARING ABS$14.42$3
WINDOW CRANK$2.70$0
WINDOW MOTOR$18.03$3
WINDOW REG W/ MOTOR$29.75$3
WINDOW REGULATOR$15.32$2
WINDOW SWITCH DOUBLE$9.91$0
WINDOW SWITCH QUAD$18.03$0
WINDOW SWITCH SINGLE$6.31$0
WINDSHIELD$31.55$0
WINDSHIELD RUBBER$9.91$0
WIPER ARM$4.50$1
WIPER BLADE$1.80$0
WIPER MOTOR$18.03$3
WIPER SWITCH$7.21$0
WIPER TRANSMISSION$11.72$3
WIRING HARNESS LARGE$19.83$0
WIRING HARNESS MEDIUM$9.01$0
WIRING HARNESS SMALL$3.60$0
WIRING PIGTAIL$1.80$0
YOKE REAR END$4.50$2
S
scholzee
Buffalo NY
Oh my bad I see you mean in junkyard, one rim is horizontal on ground and vertical rim is welded to that one. All 4 rim supports same height and cradle the frame of vehicle. Junkyard removed all jacks from vehicle and no jacks allowed in. They are all on compacted stone very clean and safe yard. One other local pull a part people jack and leave a bunch of vehicles on Jenga blocks, this yard seems much safer.
