Dash lights are out!
mag162
LI, NY
Not sure which fuse to check don't have my manual, can someone tell me where to start?
EXPI2000
Indiana
What year is your truck??? Instrument illumination fuse number 18...but I have a gen 1
Sent from my Samsung Galaxy Tab 2 using Tapatalk
M
mag162
LI, NY
Mine is also a 2000.
I'll check it when I get home from work later today
thanks
FordandPolaris
Saint Cloud, MN
If it is not the fuse, you might have to pull the cluster and see how the connections look on the back. Those had a problem with the connection for the odometer being flaky. My mom's mileage comes on and off on the display as you drive. Could be something related to that as well.
Thermo
technical advisor
mag, I will bet that your problem lies with the dimmer module in the headlight switch. You can check the fuse for the dash lights, but from what I have seen, when you have a problem like this, it is the dimmer module that fried.
Lightnig
Behind you
this might be a stupid question, but have you checked to see if all the bulbs are burnt out???
M
mag162
LI, NY
Thanks for the responses but fuse 18 was out. A little 5amp brown one.
Glad it was a quick fix.
