Dashboard cup holder/ashtray
M1757
Philadelphia, Pa
Does anyone know how to remove the dashboard cup holder on a 01 Expy? The huge metal spring came off the back of mine and I want to remove it from the dash to try and reattach the spring?
00EddieExpy
Bradenton, Florida
Just reach in behind the sliding tray from underneath with your right hand while seated in the driver seat. With the tray nearly fully pulled forward but not locked into place, reach in and you will find two plastic tabs that serve as stops one on each side. Pull each tab down and pull the drawer toward you as you do each side to allow the tray to slide past them. You should do the driver side one first then the passenger side. Once you have pulled the tray past the stop tabs the tray will come completely out. There will be an electrical pigtail connector to disconnect for the lighter. And thats all it takes. Then when you are ready to put it back in, just align to the sliders and shove it all the way in. The spring is heat staked to the back of the tray.
_________
Above was taken from an old post on F-150 forum. I pulled mine out after pulling off the radio/climate control dash bezel I just slid it open and removed it as above post says and the spring was laying in there. I ground off the plastic nubs and drilled/riveted the spring back on - works like new.
B
bedrck46
00EddieExpy Thanks for the info Just pulled mine also except the wire is for the ash tray light not the lighter on a 2001 also still have the problem as the spring is missing so now have to look in the you-pull-it yard for a spring
Not sure yet how the spring is attached but I have an idea and I may re-install with some expoy if it fits in the grove on the back of the tray
Could you possibly pull your and take a pic of how the spring mounts Thanks
00EddieExpy
Bradenton, Florida
Take a look at this link to the part on ebay - there are a couple shots that show the position of the spring, was originally mounted with some kind of adhesive that failed with time and heat. I followed somebody's post that used rivets to hold it on, now it should never come off again. I know the tray is slightly different but the rear/mounting situation is the same.
97 02 Ford Expedition F150 Truck Navigator Cup Holder Cupholder Ash Tray | eBay
B
bedrck46
Thanks for the link It appears that the 2001 expy has a slightly different cup holder/ash tray Have attached some pics of what is in my 2001
Img 623 shows whats in my 2001
Img 624 shows a single ash tray/cup holder
Img 625 shows the two tabs that need to be pushed down
Img 626 the white strip is where the spring should be attached
syntaxerror
Pittsburgh PA
Same deal happened on mine. The epoxy lasted less than a day of use before it failed. I ended up running 2 short screws through the spring into the back of the tray where the plastic mounting pins were located anyway. That's been rock solid since.
M
M1757
Philadelphia, Pa
Thanks for the reply's everyone. I did the two tiny little screw thing it's solid no. Someone else twenty years from now can deal with it again.
No members online now.
Landsbutter
