Disable Ford Expedition Alarm
hathikerry
I have a 2005 Ford Expedition Limited. Every ten minutes or so, the alarm just goes off without anyone touching the car or anything. Is there a way I can turn off the alarm, or reset it or something? Thanks.
Stoned06
Milwaukee
Is it a Ford Factory alarm, an aftermarket alarm, or the panic alarm that is going off? If it's the panic alarm, it either your keyfob is going bad, or there is a short in the system that I would have Ford look at. If it is an aftermarket or Ford installed alarm, you can just remove the module and all associated wires and all should be good.
MelWal31308
Florids
HELP!!! Nothing is working
My battery died - received a jump. Everything worked fine. Got home and got fiance to clean terminals and a alarm starting going off. No matter what we do - we cannot turn off the alarm.
I do not have a remote control, so I cannot press the panic button.
HOW do I get the alarm to turn off and stay off?
ELVATO
Orlando, FL
By alarm, I take it you mean the horn?
The Panic alarm should turn off if you turn on the truck or press the lock button on the fob (which you don't have). Try closing all the doors and locking them as well (with the door switch).
If anything, leave the truck disconnected for a few minutes (10 or so) and see if the module resets itself.
