Disappointing 4WD performance on snow.
jastevenson
AZ
Got some snow and ice recently and figured the Expy should do well with 4WD auto. Certainly, if I needed top performance in the slow I’d invest in snow tires, but I feel like the Expy should be able to deal with the relatively mild and infrequent snow here. But even on a minimal incline, 4-auto struggled to maintain forward progress.
My other vehicle (also on all seasons) has a selectable 4-hi mode that locks the differential and it has zero issues.
I think the issue with the Expy is that it waits for a lot of slip to occur before actually transferring power to the front axle, and by then it is too late.
Kind of disappointed that the Expy does not offer a manual 4-hi mode option as standard.
LokiWolf
Moderator
Richmond VA
Did you put it in Snow Mode?
Cause if you did you would have noticed a completely different behavior.
carymccarr
Earth
1) get it out of auto.
2) swap out the trash stock tires
Deadman
Wisconsin
+100000
I’ve never had such awful stocks. There was zero chance I was risking driving on them in the winter.
Stock tires are slippery as hell in snow.
I had mine "SIPED" and they are a little less horrible.
I can't get out of my driveway in 2wd because there is packed down snow on the driveway.
The EPA push has forced most to put road slicks on now, and everyone crahses in snow because of them. Its real clear in a snow here, any economy related vehicle is going turtle pack because the tires are smooth and useless.
LokiWolf
Moderator
Richmond VA
I have had zero issues with the factory 22’s. Climbed my steep driveway cover in slush and snow no problem today.
In the slush and snow in snow mode pulled out from a dead stop on a hill, no issues.
Could they be better, yes. Will I swap them with some good AT’s when the time comes, yes. But they are pretty good for OEM in my opinion.
carymccarr
Earth
What are they? Because I’ve literally never had a worse set of tires in my life than the OEMs on my Navi.
LokiWolf
Moderator
Richmond VA
Hankook Dynapro HT’s I believe....
The tire companies sell Ford and the other automakers their bottom barrel lines and low quality stock. This keeps the prices down for the automaker. It’s created a situation where the good quality stock goes out to us consumers who buy new tires direct from the tire maker and the automakers like Ford pretty much get the leftover scraps lol. They could buy better tires if they wanted though, but that cuts into margins.
carymccarr
Earth
What’s “low quality stock”?
Zig10
Mid Atlantic
I can tell you that the factory 20" Toyos aren't all that great, either. They certainly can get you out and home again in the snow, but it's not what I would consider am enjoyable experience. I'll be flipping them out for a set of Conti Terrain Contacts shortly.
carymccarr
Earth
Generally OEM tires that come on your ride are not the same quality as if you go buy tires from the same company yourself. It’s a cheaper tire. Or at least that’s the sentiment a lot of people hold these days.
Wow that’s nuts. Are they graded differently? What marking/number etc on the tires indicate that?
lv2drive
PA, USA
are you saying that if we replace our tires with an exact “oem” tire , the tire we purchase as customer to replace it has physically different properties / is technically different than the identical “looking” factory provided tire?
i find this hard to believe - if someone has a flat and purchases a single supposedly identical tire - if the tire wasn’t 100% identical in structure & material, there would be serious safety concerns with a single tire replacement - especially when considering rubber compound & related traction issues with “unmatched” tires -
any additional info to help back up this claim?
bjtor
az
I put BFG all-terrain KO2's on my 18 Expy as soon as I picked it up and have had no problems in deep snow or heavy rain.
Great tires and not too noisy.
No members online now.
rockinghranch
