It's there. I noticed that I can't see your signature picture. I had to redo mine - delete it and reinstall or reset what ever you call it.Cant see the picture
I don't think it is big enough for A/C lines going to the rear A/CIt looks like some time of separator that is used to keep battery cables apart, or transmission lines.
I'm thinking rear AC lines. Do you know if it was front, middle or rear of the truck when it was found? I'll crawl under mine tomorrow and take a look.Apparently this fell off my truck on the right side. One of my coworkers found it on ground and brought it to me. I recognize the undercoating, so I'm pretty sure it came from my truck.
I’m at the dealership getting the oil changed so I’ll ask while I’m here.I'm thinking rear AC lines. Do you know if it was front, middle or rear of the truck when it was found? I'll crawl under mine tomorrow and take a look.
Thanks Bob, the guys at the dealership checked it out while they had it up on the lift and couldn't find anything either. It is actually a rubber snap connector but not like anythingI looked under the truck on the right side and didn't see anything like that, nor anything that would use that kind of separator. Usually, the plastic snap-type separators are for electrical cabling that don't need to be anchored.
Today I lowered & checked the air pressure in the spare on my 2015 Expedition Limited 4x4. There is a very similar piece on the right rear (underneath) that holds the metal a/c lines apart (rear of the RR wheel & tire).
It was handed to me snapped together, but it could have been apart when they picked it up. It did have the same kind of sound deadening undercoating that I have on my truck and it is pretty clean because I always do the underbody wash so I think it was from the truck.Did someone snap it together after they picked it up? How could it fall off the vehicle unless it was unhooked?
This looks like something for shipping.
$50 says not part of an Expydition.
