dcarr
My trim rings just popped out. Use a smaller flathead screwdriver and gently pry. Start on the corner and once you see the tab that holds it in pry at that point. Just take your time and work around evenly
Thanks for the replies. I am going to give it a whirl next weekend. I am working on a carbon fiber project for the center console, but I need it off to get a good stencil of it.
I know this is old, but when you took off the trim around the shifter, did you pry in at the tabs? I started and one corner seems loose, (but it also seems like the "tab" is broken, before I started)
do you push in/pull out at those tabs? or just do like i do.... just pry, pry, pry (and pray)?
Thanks all
