Does my transfer case have a chain? (1999 Eddie Bauer)
TheFlyingFord
Southern Sierras
Howdy, I'll get right to the question here: Does my transfer case have a chain inside it? I know it sounds silly to ask, but I'm not too familiar with Ford transfer cases, and I've had trouble trying finding any schematics of them.
The issues I've been trying to fix are two things: The 4wd kept turning off randomly, which led to a couple butt-clenching moments while driving in deep snow last winter. The second issue is that *something* has started grinding and binding up bad when I turn. It got so bad that I removed the front driveshaft, which temporarily fixed it. This led me to believe the chain inside the transfer case had stretched. Ultimately, I'd love a second opinion before I spend half a day (or more) removing the transfer case to find it has no chain and that's not the issue. xD
Here's what I know about the truck:
It's a 1999 Eddie Bauer.
The differential locks are not vacuum actuated.
The 4x4 is electronically actuated; no vacuums.
There is a loud grinding sound when I turn, and the wheels bind up.
I removed the front driveshaft, and the grinding stopped.
My 4wd light is flashing on the dash.
I changed the transfer case shift motor around a year ago. (An early attempt at fixing the first issue.)
The dashboard 4wd actuator switch is new. (Also an early attempt at fixing the first issue.)
The dashboard actuator switch symbols are for AWD, 4 high, and 4 low. (Not sure if this helps any.)
All fuses related to the 4x4 system have been checked and are good.
Here's what I do NOT know about the truck:
I am not sure if the transfer case has a chain (obviously).
I'm not sure the model or brand of the transfer case.
I'm not sure what month the truck was built in 1999. (Not sure if this is important.)
If y'all need any more info or have any more questions, I can try to provide them. Any responses are greatly appreciated!
Thanks! -Z
joethefordguy
"...I removed the front driveshaft, which temporarily fixed it."
so you're saying it started grinding, etc. again after a short while without the front shaft; even with the shaft removed?
TheFlyingFord
TheFlyingFord
Southern Sierras
Sorry, I wrote that a bit confusing. It stopped the grinding completely and it hasn't showed up since. The "temporarily" thing was because removing the front driveshaft is a temporary thing to do. I'd like to fix it right ideally.
joethefordguy
I'm sorry, I'm still confused.
you removed the driveshaft, and the problem went away.
did you put the driveshaft back, and the problem was still gone? or is the driveshaft still out, but you intend to put it back and believe the problem will reoccur?
TheFlyingFord
TheFlyingFord
Southern Sierras
I put the driveshaft back on a few months ago, and the issue was still there. I took it out again because we needed to drive it still.
TheFlyingFord
TheFlyingFord
Southern Sierras
I agree except all confusing.
Best take to a shop to get fixed right ideally.
I don't trust the mechanics in my area. I have the skill to fix it right, I'd just like a second opinion on the transfer case chain before I spend a day taking out the transfer case. That's a lot of work for possibly nothing.
Plati
Thanks! -Z
Yes it does have a chain -->
But I can't quite get why you've focused in on that. Does your year have IWE?
Not saying thats it but seems more likely than the chain thing. Course, I dunno.
this might help maybe somewhat possibly
https://www.expeditionforum.com/threads/1999-4x4-solenoid.27435/
joethefordguy
ok, finally, I get it. sorry.
FWIW, my 04 Expy 4x4 has the BW4416 transfer case and it is chain driven. once you find out which transfer you have, you can find out whether it's a chain or gear drive.
the VIN is where I'd start looking for the transfer case model.
Goff69
