The relay is located in the fuse panel that is on the bottom lefthand corner of the dash. The relay is in the top left hand corner of the fuse panel. Here is a layout. It is Relay 1.
I'm having the exact same problems as everyone on this forum ie: bad coil on passenger side rear = leaky heater hose dripping on coil, no code to unlock door, A/C cluster panel light won't go on, dome light won't go on & tailgate emblem (whether it has holes in tailgate or just pressed on). I bought the Haynes manual and they have a pic of the fuse box but no diagram to which fuse goes where, so I pulled every fuse and they are ok. Now the relay is next. Thanks for the diagram, that's what I was looking for!! Everybody on here is helpful and has straight up answers, not pompous reactions. I appreciate it. - Hunter
