Door Ajar!
Varicolorjake
Nampa ID
Hey I'm having trouble with the driver rear door being "ajar". When the door is open i have no warning on the dash. But when it is shut the dash light appears, Ive tried spraying a little lube in there and that didn't resolve it. I've taken the panel off and can see no loose wires etc. Anyone have any tips/tricks.
Moemantha
Winnipeg
Mine did that too. I just sprayed a ton of wd inside and work the door over and over. Finally it stopped. Weird that yours isn't on when the door is actually open. If the above doesnt work, probably need a new latch.
chillin_illin
Los Angeles
Take the door latch off and remove the door switch from the latch and clean it. I had that same problem. After I did that it stopped. So I went of to clean all others.
