Driver door - outside handle
at2001Expdy
Reston, VA
Hi all,
I have a 2001 EB with ~54k miles on it. The other day when I went to open the driver door, the outside handle stayed up. When I closed the door, the latch never caught. I was able to push the handle in to get the door to latch. It has been doing the same thing ever since. I did lubricate the door hinges, catch and handle; still the same result.
When it first happend, there was no feel or sound of something breaking or coming loose.
Any ideas would be greatly appreciated.
Thanks
walnuts4x4
Watertown, NY
dont know exactly but if you take the the door panel off the inside you can see the inside the door and there is 2 (i think) screws that hold the handle on then push out the handle to get a better look... I'll be going by my friends body shop later and see if he can come up with something
A
at2001Expdy
Reston, VA
I am going to pull the door panel off this weekend if it is not too cold out. I will take a look. Is there a spring on the handle?
walnuts4x4
Watertown, NY
not 100 percent sure but i believe there is a spring of some sort... the handle isnt too hard to pull off n look
A
at2001Expdy
Reston, VA
Found the problem. The window had come out of the track due to the snow and ice and the window track was binding up against the door handle. Fixed the window and the door handle works fine (even better b/c I was able to lube all the linkages)
thanks
